snow + soft top = ? - JeepForum.com
post #1 of 16 Old 08-21-2007, 07:16 PM Thread Starter
llik1tohs1
snow + soft top = ?
i know its a bit early but with winter coming up how does the soft top hold up with the weight of inches of snow on it?
llik1tohs1 is offline
post #2 of 16 Old 08-21-2007, 08:08 PM
nycaubrun
if it is like my tj you will be fine. i like the plastic windows better because you just smack the from the inside and all the ice come right off no scraping.
nycaubrun is offline
post #3 of 16 Old 08-21-2007, 08:12 PM
Rossta
Rossta's Avatar
They hold up just fine; I've had mine for several years now, it stays outside all the time, and I've never had a problem. If it's a particularly wet and heavy snow, I'll go out and brush the snow off once it builds up - just to be safe.
But, be careful of smacking your windows too hard when they are cold, since they are more brittle and prone to breaking.
Rossta is offline
post #4 of 16 Old 08-21-2007, 09:48 PM
Durk
Now that's what I like to hear!
Durk
Durk is offline
post #5 of 16 Old 08-22-2007, 06:28 AM
JKcarp
Becareful doing that, because I put a whole right through my rear window like that. I gave it a quick tap to get everything off and it cracked the plastic window.
I've seen a guy put his ice scraper through a plastic window also.
This was on my TJ.
JKcarp is offline
post #6 of 16 Old 08-22-2007, 06:56 AM
Grant211
sorry dude, I can't help ya. I haven't seen snow since 1997.
2007 JK Unlimited Sahara
2.5" Teraflex Budget Boost, 1" MORE Body Lift, KC Slimlights, ProComp 7047 Wheels, 305x65x18 (34's) BFG AT KO's, Airraid CAI, Riddler Differential Covers, Headlight & Taillight guards, etc...
Grant211 is offline
post #7 of 16 Old 08-22-2007, 08:12 AM
squid2004
My TJ soft top holds up just fine and we had a pretty harsh winter last year. The only trouble is the wet heavy stuff will tend to freeze/bond with the top so you can't get it all off... and then later when you are going down the highway and it starts to "unstick", huge chunks will go flying and could hit other cars.
But that just makes it fun!
I'm curious how my huge JK 4-door softop will hold up.
2007 Wrangler Sahara Unlimited 4-door, Silver, 4.10, Teraflex 2.5" BB, 33x12.5x18 Toyo Open Country MT, 2" spacers, Sony video, Trail Guide GPS, TV tuner, MOPAR remote start
1998 Wrangler Sahara - built for fun - SOLD
squid2004 is offline
post #8 of 16 Old 08-22-2007, 12:02 PM Thread Starter
llik1tohs1
thanks for all the quick replies. was worried that i would come up and the build up of snow would cause the top to cave in. guess it's stronger than it seems. thanks again
post #9 of 16 Old 08-22-2007, 01:10 PM
KrasnayaZnamya
KrasnayaZnamya's Avatar
Never had a problem with my TJ, and that had the denim top, not the better top that's on the newer ones.
I'd be careful about the sheets of stuff coming off...while I agree it's pretty cool looking, you can also get a ticket for it, at least around these here parts....
Still, does look really cool as it hits the pavement and virtually explodes...
2DR X FLAME RED, 4.10 gears, bone stock...for now
KrasnayaZnamya is offline
post #10 of 16 Old 08-22-2007, 01:20 PM
PeteC
Look at where the Jeeps are designed, built and tested. Michigan/Ohio. Not exactly your sun belt.
We have plenty of JK's around here that spend all winter with the softtops in whatever Michigan can send it's way. The tops survive just fine.
'00 TJ With toys, lift and tires.
'10 Dodge Ram 1500 Quad 4x4. Daily driver and tow rig
'05 Dodge Neon. Wifes daily driver and gas sipper.
There is no Bandaid for Stupidity
Sorry if my support of legal wheeling offends you
PeteC is offline
post #11 of 16 Old 08-22-2007, 02:04 PM
packrat213
packrat213's Avatar
I am here in Northern Virginia and got my JK in Dec '06. We had several storms with some wet heavy snow, one about 8 inches. My top sagged a good bit but when I brushed the snow off it went right back into shape. Didn't have any problems. It was very easy to push the snow off in big chunks with a broom.
packrat213 is offline
post #12 of 16 Old 08-22-2007, 05:26 PM
BeerMonkeY
mine sagged alot with about 12" of wet snow on it. and water started to seep through when it got warmer, it was a spring storm.
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
BeerMonkeY is offline
post #13 of 16 Old 08-29-2007, 04:20 PM
Durk
Has anyone tried spraying (Pam Cooking Spray) on the plastic windows just b-4 a winter storm? Just wondering what it might do.
Durk
Durk is offline
post #14 of 16 Old 08-29-2007, 07:53 PM
MIKE007
MIKE007's Avatar
I use real butter and just a hint of garlic.
"That can't be more than 2 ft deep....I'd go through!"
2007 BLK Sahara Unlimited 4WD Loaded Dual Tops, 18's and Bone Stock (For Now)
MIKE007 is offline
post #15 of 16 Old 08-30-2007, 03:02 AM
pe_jeep
This was on my TJ.
Did the same thing with my old YJ, I used to run soft doors all winter as well, that was interesting some mornings.
pe_jeep is offline
Snow on soft-top LJinDelaware TJ Wrangler Technical Forum 40 11-21-2010 08:25 PM
Snow and the soft top richnev JK Wrangler Technical Forum 1 12-24-2009 05:54 AM
snow and soft top Captain56 Wrangler General Discussion 9 01-06-2009 01:24 PM
ice/snow + Soft Top xwejx JK Wrangler Technical Forum 13 12-18-2007 06:35 PM
Soft top in the snow? bigkahuna03842 TJ Wrangler Technical Forum 9 08-31-2005 10:06 AM
