Snow season coming up, how do you prepare for it? - Page 3 - JeepForum.com
post #31 of 38 Old 10-09-2013, 09:40 AM
justin credible
Just FYI to the OP; You don't want to air down in the snow, that will make you ride on top of it and decrease traction. If anything you want to overinflate.
The best example I can think of is rally cars. When they do a snow run they use hard compound skinny tires.
justin credible is offline
post #32 of 38 Old 10-09-2013, 11:24 AM
JIMBOX
Heh Heh, you can't compare 2wd race cars on hard snow to jeeps in 5' of soft snow
You airdown when you're trying to drive, in over 3' of new snow and that does make you float on top--it's a requirement if you wanna go somewhere and not spend all day digging/stuck-
Of course you won't airdown in 1 to 2 ft of snow, just drive carefully and clean the diff. humps when forward motion stops, backup, shovel hump, drive on
Fun in the snow-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #33 of 38 Old 10-09-2013, 05:43 PM Thread Starter
MoonyJohn
Hm, I guess it makes sense.. I usually aired down but I suppose its normal to stay at regular PSI. I was thinking more for rainy season, does it help traction when the roads are wet? More tire surface that way..
MoonyJohn is offline
post #34 of 38 Old 10-09-2013, 05:47 PM
brianjw
Under inflating tires increases hydroplaning.
More tire pressure keeps the tire a contact patch a little more round, and it pushes the water toward the outside edges of the tire as it should. Too little pressure and the tread gets concave, water collects in the center of the tread pattern and you are more likely to hydroplane.
brianjw is offline
post #35 of 38 Old 10-09-2013, 07:02 PM
SubAtomicGenius
2011 JK Wrangler
Take more time to get where you have to go. That's winter driving preparation.
SubAtomicGenius is offline
post #36 of 38 Old 10-09-2013, 07:27 PM
Butterjeep
2015 WK
Don't air down. If anything add air, cooler temps cause psi in hour tires to drop slightly.
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #37 of 38 Old 10-09-2013, 08:17 PM
JIMBOX
If it rains--
TAKE A CAB and support your neighborhood-
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #38 of 38 Old 01-19-2014, 11:15 PM
Spook45
Already did......bought a JEEP For extreme cold temps I add a few things to the Bug Out Bag and throw a wool blanket and sleeping bag into the back.
Spook45 is offline
