Snow Question - Stock 2008 Sahara Unlmt - JeepForum.com
post #1 of 21 Old 02-14-2010, 04:51 PM Thread Starter
krip
I'm in the northeast and found myself in a kind of bottlenck situation in a state park where due to others gettong stuck people were trying to leave the park going the wrong way on a one way.
So there I am waiting for peple to figure out who was going to back out. Going off the plowed road meant negotiating snow that was about 20 - 25 inches deep. (not really the light stuff but not super wet either). So I sat and wondered if I should just go around all teh minivans and get home or if i would end up getting stuck myself. I broke my fibula before christmas and am still on crutches having a plate and screws installed in my left leg so getting stuck mysel was especiallly not appealing.
So waht would u guys do? Would I have made it easy?
Thanks
Krip
krip is offline
post #2 of 21 Old 02-14-2010, 05:05 PM
ronjenx
ronjenx's Avatar
No.
ronjenx is offline
post #3 of 21 Old 02-14-2010, 05:20 PM
nwbronco
2014 JK Wrangler
Nope, wouldn't have been a good idea. You'd also need to air down a considerable amount to increase your footprint. And then, hopefully you'd get enough under you to pack down a path to ease onto. If not, you'd just nose into a drift with everything from the bumper and below being a snow blocker and possibly breaking the traction you might gain in the first place by airing down. Being injured, you need to stay the path, regardless of the mini-van count in front of you.
Bob
nwbronco is offline
post #4 of 21 Old 02-14-2010, 05:29 PM
little_Jeep
**IF** you were healthy and we were talking about 10 inches of snow, I'd say go for it. However, in the situation that you faced (20 plus inches of snow) and the fact that you were not healthy, I have no doubt you made the correct call.
little_Jeep is offline
post #5 of 21 Old 02-14-2010, 05:32 PM
krutj
2009 JK Wrangler
I have been in very few circumstances where 4-lo wouldn't work. Just for future ref. 4lo at a crawl in snow, with no spinning, will get you there.
someday you may need to get around.
-- Joel --
krutj is offline
post #6 of 21 Old 02-14-2010, 05:50 PM
little_Jeep
Open diff Jeep with about 11 inches of ground clearence and 20 to 25 inches of snow..... Crawl?? I wouldn't try it.
post #7 of 21 Old 02-14-2010, 06:05 PM
JeffinWesternWA
2010 JK Wrangler
low tire pressures in snow are an old INCORRECT myth...Snow tires need as "as advertised" pressures to decrease the footprint and "grip" by exposing the snow tread (narrow is more effective in snow), go w/ the door tag sticker (probably 35lbs) and pressure "up", sand and MUD need lower pressures, snow, needs MORE...(snow tires in the ol' bias belt tire days needed approx 4lbs extra to expose the tread to grip), old pro truck drivers know... it should be NO problem, even w/ open diffs and all season M&S tires on Jeep...one reason I ordered a trac lock on my '10, for when the 4wd becomes 2 WD (one front and on rear tire), brings back bad memories, but, enough years of driving 2wd cars and 4wd trucks in snow covered Maine was great experience...
JeffinWesternWA
JeffinWesternWA is offline
post #8 of 21 Old 02-14-2010, 06:10 PM
krawler510
These guys run 2-8 psi. Not saying it's the same conditions but lower pressure seems to be the ticket sometimes for sure.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #9 of 21 Old 02-14-2010, 06:45 PM
sean2857
i would have to say it all depends on what type of tires you have. i just got maxxis bighorns put on mine and i feel like i can go anywhere.i was able to go through about 10in in 2wd. granted i had a little bit of momentum built up. In 4wd i feel like i can go anywhere.
2001 XJ Cherokee.
sean2857 is offline
post #10 of 21 Old 02-14-2010, 06:59 PM
nwbronco
2014 JK Wrangler
Jeff,
You are here in the great Northwest. I have to say, it's no myth on our excursions up in the Wenatchee Forest. We may be talking apples and oranges though. A snow covered trail is vastly different than a snow covered road.
Bob
nwbronco is offline
post #11 of 21 Old 02-14-2010, 07:19 PM
ronjenx
ronjenx's Avatar
The good part about wheeling with a group is you learn what works and where it works.
And if something doesn't work, you have help right there.
ronjenx is offline
post #12 of 21 Old 02-15-2010, 07:17 AM Thread Starter
krip
Thanks for all the replies and advice. I'm glad I hung tight and waited although it was killing me to not have it a go. I think being on crutches really is what made me wait. I really need to get some experience wheeling. I'm an admitted rookie. I live just outside Princeton, NJ and there isn't anywhere real close to go that I know of. Need to keep looking and maybe hook up with a local club.
Thanks again.
Krip
krip is offline
post #13 of 21 Old 02-15-2010, 07:49 AM
little_Jeep
I agree 110%, also, you learn the correct way to do things in a safe manner, or at least as safe as it gets. When I started wheel-n, I just went out with some buddies...... didn't know it at the time, but we broke every rule. This is NOT the way to learn.
post #14 of 21 Old 02-15-2010, 08:19 AM Thread Starter
krip
can anyone recomend some clubs local to Princeton, NJ?
krip is offline
post #15 of 21 Old 02-15-2010, 09:00 AM
nwbronco
2014 JK Wrangler
nwbronco is offline
Replacing stock tyres on 2008 JK 2dr Sahara Cleggmeister JK Wrangler Technical Forum 3 12-13-2009 05:55 PM
2009 Jk X vs 2008 Jk Sahara JeepPoppa JK Wrangler Technical Forum 17 09-16-2009 06:30 PM
Is the stock bumper on 03 sahara (color question) staquinas TJ Wrangler Technical Forum 3 07-28-2009 07:22 AM
2008 SAHARA Studded snow tires jeepcouple JK Wrangler Technical Forum 6 10-09-2008 07:47 AM
2000 Sahara stock 16" rim question... Downsouth TJ Wrangler Technical Forum 3 05-21-2007 08:57 PM
