Smell gas after hard run all day In 4L - JeepForum.com
post #1 of 24 Old 08-30-2012, 06:22 AM Thread Starter
towerassoc
towerassoc's Avatar
Location: Prescott,AZ Summer, Sun City West, AZ winter.
I did a run all day in 4 low and when stopped, I would have a strong sell of gas in my 2012 2dr.
Can't find any fuel leaks. Anyone have an Idea what is causing this???
Thanks
Bill
towerassoc is offline
post #2 of 24 Old 08-30-2012, 10:52 AM
1222
RIP John
1222's Avatar
That used to happen with my í08 a lot. It was always on a very hot day though. So far with my 2012 itís happened once, but then I havenít been using my Jeep as much this summer as I did my í08. I wish I could tell you why it does it but I donít know. I did go to the dealer a few years back and was given some stupid *** answer for why it might be doing it and sent me on my way. Others have experienced the same smell too so itís not an uncommon occurrence.
Also, the gear you are in has nothing to do with it. You could be in 2wd and it will still happen.
(2011-2016)
1222 is offline
post #3 of 24 Old 08-30-2012, 11:09 AM
4x4jkx
Exhaust leak? Driving slowly in 4lo you will smell it more.
4x4jkx is offline
post #4 of 24 Old 08-30-2012, 11:57 AM
1222
RIP John
1222's Avatar
Has nothing to do with that. This is definitely gas smell. There have been times when taking lunch breaks or whatnot that we have had to setup our camp chairs several yards from the Jeep so as not to be overwhelmed with the smell. It can get bad at times.
(2011-2016)
1222 is offline
post #5 of 24 Old 08-30-2012, 03:54 PM
1AAdam
maybe the vent system burps it out a bit especially if at extreme angles?
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #6 of 24 Old 08-30-2012, 04:06 PM
gonwhln
Rotopax or jerry cans on the jeep?
Evo rear King Coilovers, Recon front King Coilovers, Rock Krawler all 8 control arms & links, CV driveshafts, removed rear sway bar, Custom skids, Viair OBA with dual compressors mounted behind tailights & 2gal tank, Warn M8000, Body Armor rear bumper and carrier w/custom rotopax, front Poison Spyder Brawler lite bumper, Herculined tub, Cobra 75wx cb, daystar switch panel, Hella lights, custom cut fenders, 17" black alloys w/ 35" treadwright Guard dogs, Gusseted and regeared to 5.13's, Teraflex drag link flip, cut and dieted, Benchmark HD oil pan, RK deep sump HD tranny pan.
gonwhln is offline
post #7 of 24 Old 08-30-2012, 05:55 PM
1222
RIP John
1222's Avatar
Nope, no gas other than what was in the tank, not sure of the OP. Good guess though.
(2011-2016)
1222 is offline
post #8 of 24 Old 08-30-2012, 06:03 PM
joe002
I'm in the same boat. I think elevation changes and temperature changes seem to trigger it. No lights, just stink.
2008 Rubicon - 2 Door - Flame Red - Automatic - MyGIG - Power Group - Deep Tint.
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Stubby Bump, Currie F/R Adj Trac Bars, Daystar Upper Dash, FireStik FireFly antenna, Kilby Rear Shock Skids, LoD Sig Stubby Bump, Midland 75-822 CB, Mopar Filler Door & Locking Gas Cap, Rancho LCA Skids, Rancho Oil Pan Armor, Riddler Diff Covers, custom Rubi Sliders, Sylvania X-treme Headlights, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relo, Woods SS Relo, Yukon 5.38s
joe002 is offline
post #9 of 24 Old 08-30-2012, 09:57 PM
saddis
2014 JK Wrangler
Have you checked your evap canister for a crack since the trip?
Steven
saddis is offline
post #10 of 24 Old 08-31-2012, 08:49 AM Thread Starter
towerassoc
towerassoc's Avatar
The Evap Canister is OK, but does it have a relief value and could that open when the canister can keep up?????and thats the gas smell???
post #11 of 24 Old 08-31-2012, 06:50 PM
mjp83
2011 JK Wrangler
My 2011 JKU did the same thing during a recent heat wave. Was towing camper and also wheeling that weekend. Now that it's been cooler no smell! I have no aux gas cans, and my jeep has 0 trail damage.....
mjp83 is offline
post #12 of 24 Old 08-31-2012, 07:40 PM
VEGASROBBI
Jeep equipped the JK (2007-2011) with a primitive EVAP system. It is not closed loop and depends in a ESIM (EVAP system integrity monitor) for fault monitoring, At least they got rid of the LDP on the JK.
Your JK depends on a spring loaded valve to relieve excessive pressure/vacuum in the fuel system. The ESIM is a crude device meant to meet monitoring requirements.
The reality is on a hot day when vapors are pevelant , especially in 4WD low when the vehicle is moving slow and the engine revs are high you may smell fuel. This really bothered me with my family on board off road, but there was nothing wrong.
One big advantage to the GM LS Gen IV engine is virtually 0 EVAP emissions. We run a true FTP (fuel tank pressure sensor) and a EVAP vent solenoid. The system receives feedback from a true analog 3 wire FTP sensor and acts using the purge valve and EVAP vent solenoid.
The system stays active even with the key off and you not in the vehicle, the ECM monitors the fuel system at all times.
In addition Gen IV engines use new technology gaskets that seal better so HC molecules do not penetrate the gaskets. Variable speed fuel pumps, no fuel return line, and other technologies allow the LS to run virtually EVAP free.
I can tell you I don't miss that fuel smell off road in my JK. When we would stop for lunch we had to camp away from the vehicle.
MoTech
LS Specialists
500 South Buffalo Drive, Las Vegas NV 89145 702-491-7710
www.LSWrangler.com
VEGASROBBI is offline
post #13 of 24 Old 08-31-2012, 07:52 PM
joe002
VEGASROBBI - So I guess weíre stuck with the occasional stink?
joe002 is offline
post #14 of 24 Old 08-31-2012, 08:02 PM
1222
RIP John
1222's Avatar
Originally Posted by VEGASROBBI View Post
...When we would stop for lunch we had to camp away from the vehicle.
Thatís exactly what we would do too; itís either that or be overwhelmed with gas fume smell. It can also penetrate the cabin. One time we had to roll down all the windows and drive faster to clear the cabin of the fumes.
(2011-2016)
1222 is offline
post #15 of 24 Old 08-31-2012, 08:15 PM
VEGASROBBI
Originally Posted by joe002
VEGASROBBI - So I guess we’re stuck with the occasional stink?
This is correct, the Jeep ecm has no way to control venting it is accomplished by springs.
It works fine in most situations, but like the Pentstar if you drive it in a specific manner and run certain gas = not so good.
MoTech
LS Specialists
www.LSWrangler.com
Striker from full hard doors appears too big for hard half door? LEOinFL YJ Wrangler Technical Forum 1 05-24-2010 09:31 AM
Hard Top - Hard Doors Improvised Rattle solving thread bparsel YJ Wrangler Technical Forum 7 07-22-2009 07:23 PM
Half Hard Doors vs Full Hard....Key Cylinders Swappable? Hunta TJ Wrangler Technical Forum 17 05-13-2009 02:57 PM
hard half doors/sliding windows/hard top tomthbomb YJ Wrangler Technical Forum 7 07-13-2007 07:42 PM
Who Sells Hard Door Inserts that match the Hard Top gtospeeding TJ Wrangler Technical Forum 7 05-06-2007 10:15 AM
