Slow wobble during u-turn on pavement while in 4x4 - JeepForum.com
post #1 of 12 Old 07-21-2010, 09:16 AM Thread Starter
cadeddie
ok took my 2008 JKU for some light offroading in the sand this weekend for the first time...(with 35")
I was driving thru some sand and jumped on a paved road really quick to do a turnaround (u-turn)...while doing this turnaround I noticed this uneasy slow wobble like if coming from the tires (while doing the u-turn on pavement only) is this normal?
Everything went back to normal once i got back on the sand and driving straight again.
Drove back home perfectly after that
what do you guys think?
cadeddie is offline
post #2 of 12 Old 07-21-2010, 09:20 AM
1398653
2017 JK Wrangler
dont use 4 wheel drive on pavement unless it is covered in snow. It is bad for the jeep and will eventully cause damage. What you are describing sounds normal when one attempts to drive in 4 wheel drive on pavement but cannot be too sure becasue I have never done it. I only use 4 wheel drive off road in low and rarely use 4wd high.
Steve, Allegany NY, 2017 JK Unlimited Rubicon
1398653 is offline
post #3 of 12 Old 07-21-2010, 09:31 AM Thread Starter
cadeddie
I jumped on the pavement to do a u-turn for like about 15 seconds....that is all....by the way thanks for the reply
cadeddie is offline
post #4 of 12 Old 07-21-2010, 09:39 AM
jerseyjeep2003
This sounds normal, as your driveline is trying to bind up due to the wheels having traction. engaged 4X drive + DRY pavement = broken Jeep. Actually, short (25 feet or so) straight and s l o w won't hurt, as long as ya don't make a regular practice of it.
95 YJ 8" of lift 36" Iroks, & more mods than I can really afford. The General Lee....YEEEEHAA
href="http://s488.photobucket.com/albums/rr249/jerseyjeep2003/General%20Jeep/?action=view&current=trailride7-6-08105.jpg" target="_blank">http://s488.photobucket.com/albums/r...e7-6-08105.jpg
jerseyjeep2003 is offline
post #5 of 12 Old 07-21-2010, 09:47 AM
mikek3
This is normal when using 4 wheel drive on a dry road/pavement. However, extended use like this is not good for your Jeep.
mikek3 is offline
post #6 of 12 Old 07-21-2010, 09:55 AM
Ravik
2010 JK Wrangler
FYI: Driveline bind, binding hubs, axle wind up, axle bind, drive line wind up - all terms for one thing: stress due to part time 4 wheel drive
Basically, to go in a circle, the outer wheels have to turn faster as the radius of the circle is bigger - hence why we have differentials. When in 4WD, all of the wheels turn at the same speed, so going around a corner will cause incredible torque on the driveline components and 'wheel hop' as the inner or outer wheel looses traction and skips on the pavement.
Hopefully you didn't break anything.
2010 2dr Rubicon
Ravik is offline
post #7 of 12 Old 07-21-2010, 10:11 AM Thread Starter
cadeddie
wow I am glad I asked....I had the idea of what was going on....just needed reassurance ..thanks guys
cadeddie is offline
post #8 of 12 Old 07-21-2010, 12:58 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Sorry to be controversial, but if the differentials are NOT locked, then not all the wheels have to turn at the same speed - the differentials are still open so wheels on the same axle can turn at different speeds, BUT, the front axle and rear axles are linked by the transfer case and hence the driven wheel on the front and rear axle will tend to bind up when turning. If your differentials are locked, then yes, severe binding can and will occur.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #9 of 12 Old 07-21-2010, 01:20 PM
trw
2011 JK Wrangler
this. This is why only Fulltime 4WD or AWD can operate on dry pavement since the transfercase acts like an open differential and allows the 2 axles to rotate at different speeds, part time does not and locks both axles together (part time is superior offroad though, but some fulltime set ups include a locking feature for the Tcase to make it act like a part time Tcase such as my Quadratrac CJ thus giving the best of both worlds).
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #10 of 12 Old 07-21-2010, 01:21 PM
strat_53711
2009 JK Wrangler
Technically, correct if using lockers. The inside/outside wheel will cause bind and stress at the differential. This could lead to differential damage.
But this does not explain what is happening at the transfer case (either locked or unlocked differentials).
From what I've been told, the binding at the transfer case, occurs due to the tracking differences between the front wheels and the rear wheels while turning. When making a turn, the front tires actually travel a small percentage farther than the rear tires (drive through a puddle with your bicycle and you can see that your rear tire will cut inside the track of your front tire). On high traction surfaces (pavement), this puts extreme stress on your Jeep's transfer case. On low traction surfaces, the tires can slip, and it reduces the stress.
Someone correct me if I'm incorrect.
2009 Jeep Wrangler X, Flame Red, 6 Sp Manual, 23S Package, 3.73, TracLok, Tinted Windows, Sirrius Radio, Half Doors
strat_53711 is offline
post #11 of 12 Old 07-21-2010, 01:30 PM
RockyClymer
RedRock4Wheeler
strat_53711
I agree with you - the tcase is locking the axles and tracking is causing the bind - what I said. Regards, Rocky
NRA Life member
post #12 of 12 Old 07-21-2010, 02:37 PM
KPJ
2010 JK Wrangler
The same issue arises on hard packed dirt, btw, or on rock.
JPK
KPJ is offline
jk , wrangler , 4x4 , 4hi , 4 lo , turn , turning , wobble
hard to turn at slow speed purevil115 TJ Wrangler Technical Forum 6 12-04-2009 07:14 PM
2.5 is slow to turn over jeffyp06 TJ Wrangler Technical Forum 12 09-25-2008 12:33 AM
Slow turn signals blue1989yj YJ Wrangler Technical Forum 12 11-03-2007 11:08 PM
stalls during slow turn Jeeptastic TJ Wrangler Technical Forum 1 05-27-2007 03:29 PM
Slow right turn problem rob5059MOD TJ Wrangler Technical Forum 4 11-17-2006 05:48 AM
