Slow to unlock - JeepForum.com
post #1 of 6 Old 09-06-2013, 08:43 AM Thread Starter
ETZFAM
2010 JK Wrangler
Slow to unlock
2010 JK Rubicon, hard to unlock the electric lockers?
Need to back up?
Thanks
Rick
ETZFAM is offline
post #2 of 6 Old 09-06-2013, 09:09 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
No need to back. They do require a bit of time but more importantly some axle movement to fully lock/unlock. Usually I hit the switch while approaching allowing about 5-10 feet for the light to go solid. Then when unlocking I just hit the switch and go - sometimes it takes a few feet to unload enough to unlock - especially if axle bound from trying to turn. I would say that if you need to turn tight so dont have the few feet to spare - rock back and forth to unbind and it should unlock pretty quick - i have had to do this when going from both locked to rear only - the fronts do bind more (as they are steering).
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #3 of 6 Old 09-06-2013, 09:10 AM
duneslider
Sounds like this is a fairly common problem. I don't have a rubicon so i haven't followed it much but try some searches and see if you can find the root cause.
Some guys have to use a screw driver to move the ring inside to get it to unlock.
duneslider is offline
post #4 of 6 Old 09-06-2013, 11:32 AM
HappyTrails
HappyTrails's Avatar
Just be sure to do that while your Jeep is facing UPHILL or it could become messy.
And duneslider is talking about unlocking the front locker like this: http://www.jeepforum.com/forum/f96/s...ocker-1569533/
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #5 of 6 Old 09-07-2013, 04:08 PM
73azbronco
also turn the wheel slightly left to right it unloads the splines to let it unlock/lock quicker.
73azbronco is offline
post #6 of 6 Old 09-07-2013, 06:45 PM
Reluctant
my 13 JKU Sport is slow to unlock...I think it's because i don't have keyless entry
To truly appreciate Obamacare, you should be not working, undocumented and given it for free.
Reluctant is offline
