Which skids get the most use? - JeepForum.com
post #1 of 9 Old 09-13-2009, 11:05 PM Thread Starter
cb19950
Buddy and I are going to Uwharrie in a few weeks...hes has a completely stock jk Sahara....which skids to yall consider the most important?
thanks
2000 TJ
When we do right, no one remembers. When we do wrong, no one forgets.
cb19950 is offline
post #2 of 9 Old 09-14-2009, 12:33 AM
BrettDez
Personally, I'd go with an engine/oil pan skid plate. I have a skid row one and it's taken a beating, glad I have it.
-Brett
My Jeep: 2012 Jeep Wrangler Unlimited Rubicon, 6-Spd Manual, Cosmos Blue
"The Smurf":
Previous Jeeps:
BrettDez is offline
post #3 of 9 Old 09-14-2009, 12:36 AM Thread Starter
cb19950
how important is gas tank skid and what about that evap can?
2000 TJ
cb19950 is offline
post #4 of 9 Old 09-14-2009, 03:24 AM
versoel
2009 JK Wrangler
You wont have any issue at URE. I took my 4d rubicon there without a lift and it did just fine. i didnt even touch the lockers. i had to use creative driving around the humps that are there for erosion control. i had to drive it like a lowrider over a speed bump, start on the left drive along it then down.
09 JKU Rubi, 37s, 3.5 Rock Krawler lift with 3 link rear
versoel is offline
post #5 of 9 Old 09-14-2009, 06:42 AM
BrettDez
You have a factory fuel tank skid and I haven't moved or protected my evap and haven't had an issue.
-Brett
"The Smurf":
Previous Jeeps:
BrettDez is offline
post #6 of 9 Old 09-14-2009, 11:21 AM
tricked919
this is one of those things that you might get a different response from everyone. I used to play at Tellico all the time before the tree-huggers took it away from us. My gas tank skid took a beating, but the stock unit is sufficient. I actually opened up my front diff cover on trail #6, so with that being said, I thing diff covers are a great start for beefing up. On the JK, the diffs and the lower shock mounts are the most vulnerable. As much as my JK has been through, the evap and oil pan have faired pretty well.
tricked919 is offline
post #7 of 9 Old 09-14-2009, 01:08 PM
AlterEgo
I wrecked the original OEM trans skid and crossmember. So, I put a Skid Row engine trans skid on it and now thats all scratched up but not bent. I already moved the Evap Can so that's not an issue. The gas tank skid is bent, but the tank still holds 19 gallons so its not up for replacement yet. The Riddler and Solid diff covers have a few scrapes but are still in excellent condition. One control arm mount is bent but still usable. I probably won't skid those.
Gary Greenway - KD8NHC
08 4 Door Rubicon
Member of Two Trackers 4wd Club
Great Lakes Four Wheel Drive Association
United Four Wheel Drive Associations
AlterEgo is offline
post #8 of 9 Old 09-14-2009, 02:00 PM
PanthersFan
Stock skids are fine at Uwharrie. I beat up my Fuel Tank skid on Kodak Rock, but there's an easy bypass around it. You'll have a blast!
THE Conventions of a number of the States, having at the time of their adopting the Constitution, expressed a desire, in order to prevent misconstruction or abuse of its powers, that further declaratory and restrictive clauses should be added: And as extending the ground of public confidence in the Government, will best ensure the beneficent ends of its institution.
PanthersFan is online now
post #9 of 9 Old 09-14-2009, 04:24 PM Thread Starter
cb19950
Thanks guys ill let him know!!!
2000 TJ
cb19950 is offline
no BL skids ribs TJ Wrangler Technical Forum 4 03-17-2008 11:39 AM
Can Skid Row lca skids and engine skids be used together? WranglerTom TJ Wrangler Technical Forum 4 07-30-2006 01:57 PM
Prep question for LCA skids (JKS Mini Skids) VinoTJ YJ Wrangler Technical Forum 3 03-06-2006 08:44 AM
LCA Skids tiger-bailey TJ Wrangler Technical Forum 2 01-28-2005 06:26 PM
Skids --> engine skids / diff skids. What brand and Style? Sparty TJ Wrangler Technical Forum 9 03-25-2004 03:30 PM
