Skid plates - Help - JeepForum.com
post #1 of 5 Old 12-08-2012, 02:30 PM Thread Starter
Paio2012
Skid plates - Help
Guys: I need some protection for the lower part of my stock 2012 JK Automatic. I have seen several skid plates manufacturers and I need recommendations. I usually take regular gravel/ dirt roads and occasionally I do light tracks with rocks which could damage the lower part of the Jeep. My question is what do I need to protect? I was looking at my oil pan and it is completely unprotected... It is enough just the skid plates for the oil pan, transmission and catalytic converter? Do I need for the transfer case? EVA canister? Any fairly good product and reasonable cost suggestion? I have no intention to lift the Jeep since I use also for work commuting and the parking lots over here are unfortunately not made for tall ones... Thanks in advance all.
2012 Sport S - JK Wrangler
Deep Forest Green
Paio2012 is offline
post #2 of 5 Old 12-08-2012, 02:54 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
As long as it hits where the stock protection is at, I would not worry...now if you are rock crawling and hit other places, well they need protection. I have yet to hit my oil pan or evap canister, but, I do have a front diff skid, a rear diff/DS skid, and rock sliders that get regular use. Once a year I just drop the stock skid plate, beat any bumps out and repaint it...for me, more protection is not needed and just adds needless weight. Just my opinion though.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 5 Old 12-08-2012, 03:59 PM
SoK66
2009 JK Wrangler
For most the stock t-case & tank skid will be marginally OK, but the things really need some trans protection. Plus, the factory crossmember is a POS. Really recommend at last something like M.O.R.E.'s combo oil pan & trans skid, or perhaps Rockhard 4x4's setup. The latter's complete skid system is strong & cost effective. I have the full Synergy skid system which has been subjected to everything from Moab Rim to Mt Blanca and looks it but has protected the vitals well. It is a heavy system and prolly overkill for most applications, it's just that you don't want to learn the fail point of those stock skids and whatever that bar thing is they put over the trans pan.
SoK66 is offline
post #4 of 5 Old 12-08-2012, 05:12 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
I have the Skidrow's engine, evap and LCA skids, Warn differential skids for front and rear diff's, and Rock Hard gas tank skids.
If I had to do it over again, I would get Rock Hard engine, gas and tranny skids which provides contigious coverage. After that, LCA and diff skids are absolutely necessary when crawling rocks.
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
post #5 of 5 Old 12-08-2012, 05:20 PM
08rubinewb
I ordered the package deal northridge has that covers the oil pan cross member (bends easily) and the transmission. http://www.northridge4x4.com/shop/of...ek-skid-system Can't wait to get a nice day so I can install it!
08rubinewb is offline
