Single Person JK Hardtop Removal?? - JeepForum.com
post #1 of 40 Old 06-18-2007, 03:08 PM Thread Starter
Corleone
I want to remove my JK hard top every now and then but my wife cannot help me lift it and I hate to ask people to come over and help me lift off the top. Does anyone know of a product and/or has anyone rigged anything that would enable me to remove the hard top by myself. I do not have a garage so I cannot use the pulley system. I can use a hand truck to move it to my backyard but getting the top off the body and onto the ground is the problem. Any ideas?
Corleone is offline
post #2 of 40 Old 06-18-2007, 03:23 PM
MichaelW
MichaelW's Avatar
I just picked up mine and carried it to the backyard on my 4-door hardtop. But it was a tricky balancing act.
Some ideas,
A tall engine hoist like lift.
A lift system similar to sleeper campers with jacks available at RV stores.
A single large overhead beam with a come-a-long.
There are probably some after market products available as well.
Michael W
Welcome to the Free World!
MichaelW is offline
post #3 of 40 Old 06-18-2007, 03:37 PM
CCrew
Make, or buy one of these.
http://www.quadratec.com/products/12020_1X_A_PG.htm
-Roger
CCrew is offline
post #4 of 40 Old 06-18-2007, 03:45 PM
JEEP97TJ
-Roger
He said he doesnt have a grarage, so he cant really do the pulley system
Blacksburg, VA
JEEP97TJ is offline
post #5 of 40 Old 06-18-2007, 04:39 PM
jprubiconTN
I have the Lange Lift and love it.
Since you do not have a garage - do you have a tree that could hold it?
jprubiconTN is offline
post #6 of 40 Old 06-18-2007, 04:49 PM
surfcaster
If you have cool neighbors they will not mind helping you for 45 seconds in the spring and the fall. Get yourself the hardtop cart and once it's on the ground you can move it anywhere by yourself.
surfcaster is offline
post #7 of 40 Old 06-18-2007, 05:46 PM
JEEP97TJ
I was thinking, do you have a deck of some sorts? If you have a deck off the normal living level with a walk out basement, could rig something up to the bottom of the deck, back jeep under it, raise the top and store it there.
Then again you might not have a deck........just throwing out ideas
So if you have the hard top, its gotta be the 3 piece freedom top, right?
So I guess you can handle the smaller parts. My TJ has a 2 piece hardtop, front cockpit half can be handled easy, but that dang back part needs 2 people, thought of doing it myself but reconsidered. Haha.
good luck
Blacksburg, VA
JEEP97TJ is offline
post #8 of 40 Old 06-18-2007, 08:57 PM
BJeepJK
Easy Fix ... get at least 2 cases of beer, call up a few friends and have alittle cook out. After a few beers mention that you were thinking of taking the top off but its too heavy for the wife. Your buddies will have it off in no time.
A few years ago I poured a concrete slab and had a bunch of lumber piled up around it, called over my buddies for a party and drank some beers then one of them asked "what do you have going on over there?" I said come on over and I'll show you, next thing you know I had a garage ... Luckily I have a keg mister cuz it took us 2 full days of drinking to build it. It's still standing, and pretty level too ... LOL
BJeepJK is offline
post #9 of 40 Old 06-25-2007, 03:48 PM Thread Starter
Corleone
Thanks
Thanks for all your ideas. I didn't think about the tree idea.....I do have a tree nearby that I could use along with the lange hoist.
Thanks again!
Corleone is offline
post #10 of 40 Old 06-25-2007, 04:35 PM
fer328
I tried to build a pulley system this weekend. The top itself is not that heavy, just large and difficult to manage. For those of you who are going to make yourself, the center of gravity is almost to the very back of the roof. With a single hoist (pulley) at the top ( as in attached to a ceiling) it is still very cumbersome for one person to lift and set on roof . I am going to try to add another pulley ( 2 pulley system to see if it will be easier to lift. I knew I should have paid more attention in physics.
fer328 is offline
post #11 of 40 Old 06-25-2007, 07:44 PM
Krieglok
Krieglok's Avatar
Maybe a fellow JK owner in NJ could help you lift it off...Are there any jeep(ing) clubs in North Jersey?
TJM
2007 redrock auto JK 4dr(Hers), 2007 rescue green stick JK 4dr (His)
Krieglok is offline
post #12 of 40 Old 08-02-2007, 07:17 AM
SaharaBlackNo1
I'm going to assume you got the power winch and not the manual. I decided I didn't need power and got the manual. The winch they provide is garbage. The T is a pretty good design though, but the 6 lousy screws that are supposed to "hold" the parts together are junk as well. I broke 4 out of 6, stripped a 5th and left the 6th looser than I'd have liked. I then drilled out the 4 I broke and drilled holes through the piece and replaced the sub par screws with longer ones. Its now very sturdy and I don't feel like it might fall apart on me.
For 200 bucks though they could have at least provided a better winch I feel. I'm going to Harbor Freight today to pick up a 30 dollar manual winch with hand brake. The one Lange provides is not really designed to lower anything, just pick it up.
SaharaBlackNo1 is offline
post #13 of 40 Old 08-02-2007, 03:36 PM
catchone
MOD or BUST!!!!
catchone's Avatar
I took mine off by myself. Like MichealW the balancing was a little difficult but it can be done. Just remember to have the window up and the tailgate closed.
It slides off very easy. I am 5'8" so I am vertically challenged.
Once you start you are committed. Taking off by yourself is one thing
Putting on by yourself is a totally different thing.
catchone is offline
post #14 of 40 Old 08-02-2007, 03:39 PM
cadencedad
cadencedad's Avatar
I cemented to 4 x4s and the 3rd across the top and put a winch on the top and blasto you have it all for under 100.00
cadencedad is offline
post #15 of 40 Old 08-02-2007, 04:46 PM
squid2004
I first setup a deal with sawhorses and a platform that I would simply back up and slide the top on and off to... worked very well and handled an entire TJ hard top all by myself.
then in my garage I setup four locking ropes and attached to each corner and basically cranked two up at a time an inch or two until it cleared the jeep.
2007 Wrangler Sahara Unlimited 4-door, Silver, 4.10, Teraflex 2.5" BB, 33x12.5x18 Toyo Open Country MT, 2" spacers, Sony video, Trail Guide GPS, TV tuner, MOPAR remote start
1998 Wrangler Sahara - built for fun - SOLD
squid2004 is offline
Hardtop Removal/Storage Solution - One Person Operation DeepSky JK Wrangler Technical Forum 42 11-30-2011 06:42 PM
One person spring removal/install Snuffster TJ Wrangler Technical Forum 21 03-15-2007 10:59 PM
Hardtop Paintjobs-need photos-single color top & body SpaComponents TJ Wrangler Technical Forum 3 01-18-2007 12:33 PM
Single Handed Hard Top Removal mdot TJ Wrangler Technical Forum 23 04-20-2006 01:06 PM
Hardtop Removal Chris773 YJ Wrangler Technical Forum 2 05-02-2004 07:43 AM
