Since I am new to the whole Manual transmission... - JeepForum.com
post #1 of 13 Old 12-22-2009, 07:09 AM Thread Starter
Yellow09Jeep
Okay I know how to drive a manual and do all the shifting fine. BUT I need to make sure I know what NOT to do on the trails with a manual and any tips or tricks before I go out to do some major wheeling... I don't wanna screw my transmission up before 5000 miles... hahaha Thanks Guys!
Yellow09Jeep is offline
post #2 of 13 Old 12-22-2009, 07:18 AM
mantis
X2 on this question.
mantis is offline
post #3 of 13 Old 12-22-2009, 08:14 AM
hansonian
All my Jeeps have been manuals and I've never done anything special when I'm off roading. Drive it appropriate to the situation and you should be fine. What kind of off roading are you plan on doing, i.e. mudding, rock crawler, trail riding, water crossings?
2004 LJ - Yellow
2008 JK X - Jeep Green, 6spd, Home Made Stubby Bumper, MasterCraft Grab Handles, Husky Floor Mats SOLD
1995 YJ - Anemic 4 cylinder, 5spd SOLD
1969 CJ5 - Ran into the ground and left for dead
hansonian is offline
post #4 of 13 Old 12-22-2009, 08:21 AM
mdm
Farm Wheeler
Don't ride the clutch pedal. In tough obstacles use 4Lo, get off of the clutch and let the engine work for you. In the long run you are usually better off letting the engine kill itself rather than smoking the clutch trying to ease through.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #5 of 13 Old 12-22-2009, 08:23 AM Thread Starter
Yellow09Jeep
More than likely I will only be doing trail riding, some mudding and easy crawling. I keep seeing that if i am submerged not to push the clutch in... Why? And is this true? Thanks!
Robin
post #6 of 13 Old 12-22-2009, 08:27 AM
rev353
+1 <drive it normal, and yes use your low range> I took mine out on Thanksgiving, I lugged the 4.0L down so much that the dash lights came on. Just take your time and have fun with it.
rev353 is offline
post #7 of 13 Old 12-22-2009, 10:33 AM
1398653
2017 JK Wrangler
Use low range anytime you are on something that is rougher than a dirt road. If you are on rough terrain, put it in first gear low and let the engine pull you along and blip the throttle anyting you need a little more to get over somthing. there is no need to apply constant throttle in 1st gear, the engine will keep you moving for the most part. The less you use the clutch the better. When you are going up a steep grade where you know wheel speed will be necessary (mud or lose dirt) put it in 2nd gear to get up the hill. For off roading purpose, you will never need higher than 2nd gear low range. It is also important to air down your tires so they can go over rock and logs easier. If you feel that you are going to stall going up a steep grade, do no push in the clutch, just let it stall. Start up the jeep in first gear with both your feet firmly on the ground, do no touch the clutch or gas and the jeep will start moving forward. It is important to not push the clutch in on very steep grades going down becasue you will lose control very quickly, pick your gear before you start down the hill and stick with it. The only exception is if you are going down a short very steep slippery grade and you start to slide sideways, you may need to puch in the clutch quickly to stop the side slide. sometimes if you are on a very slippery slope, if you are in too low a gear, it may feel like you are applying the brakes and starting to slide sideways.For wter and deep mud choose your gear before you go in and stick with your gear, no shifting in water, if you stall in water use the above method of starting in gear dsicussed above unless you took on water then do NOT start up your jeep, get towed out and figure out if water got in the engine.
sorry for the long ramlbling post but these are some of the off roading tips I can think of with a stick shift.
Steve, Allegany NY, 2017 JK Unlimited Rubicon
1398653 is offline
post #8 of 13 Old 12-22-2009, 12:07 PM
08BlueSahara
May have been answered, but if not.....
It's because when you're in dirty water, the dirt will get between your clutch plate and flywheel and GRIND when you release the clutch. You'll possibly score your flywheel surface and damage your clutch plate and need to replace.
08BlueSahara is offline
post #9 of 13 Old 12-22-2009, 12:34 PM
rirrgang
I wouldn't do any "major" wheeling until you learn to do some "minor" wheeling first, while learning the manual tranny thing.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #10 of 13 Old 12-22-2009, 03:51 PM
justjeepinorfw
Wow, you do learn something every day!
I've had a manual Jeep and been in a club for about 15 years and I've never heard the water clutch thing.
-O|||||||O- Have fun out there. Jeep
justjeepinorfw is offline
post #11 of 13 Old 12-23-2009, 05:52 AM
Voyame
That's pretty lucky! Especially if you've done a lot of clutching in deep water/mud crossings. There's a little gap at the bottom of the clutch housing, just big enough for water/mud to make it's way in if it has enough time. Look under there and notice it's location in relation to something on the body so you'll know when to stay off the clutch. It's not all that low but low enough to be aware of the dangers. I figure if water is up to the bottom of the front fenders I'm not going to clutch it. If water is over the bottom door hinges I'm starting to hope for higher ground. When I start bouncing down stream with the current the pucker factor really starts to peak.
Voyame is offline
post #12 of 13 Old 12-23-2009, 06:57 AM
justjeepinorfw
Thanks, I'll have to keep that in mind.
post #13 of 13 Old 12-23-2009, 09:47 AM
08BlueSahara
Water Fording in a Jeep
...On a related topic - This is some AMAZING info on the history of Jeep water fording:
Evolution Of Deep Water Fording and the Jeep
jk manual transmission munky_3434 JK Wrangler Technical Forum 32 02-24-2010 07:21 PM
JK Manual Transmission always JK Wrangler Technical Forum 4 11-09-2006 03:30 PM
87 Manual Transmission duke32 YJ Wrangler Technical Forum 5 08-06-2006 08:13 PM
Which Manual transmission? domano 68 TJ Wrangler Technical Forum 15 05-15-2006 09:55 PM
New Manual Transmission SpitNine TJ Wrangler Technical Forum 3 04-15-2004 12:11 PM
