simple kayak racks..thoughts?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > simple kayak racks..thoughts??
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO April Instant Rebate: Up to $75 off Flowmaster Products!50% Off Sale at KrawlOff-Road.com
Unread 01-10-2015, 04:04 PM   #1
yycwrangler
2014 JK Wrangler
Planning ahead and would like to be able to put two single kayaks on my jkus 4-5 times per year. Because of the lack of need (other than the kayaks), I would like to come up with a way to take the rack off the jeep when not used. I'm not looking to spend a lot of money and don't want a full cage. So far I have come u with buying a roof lightbar (one that connects to the side of the front window) for the front and then maybe a goalpost type hitch mount for the back or a similar tubular bar that can be attached and detached relatively easy.
So my question is..has anyone gone this route of can suggest something similar. I'd love to find a front windshield mount where I can leave the mounting brackets connected to the windshield, and via a couple of pins, remove the lightbar when not needed..Is there such an animal
Any other suggestions would be greatly appreciated or if you have a diy even better
Cheers
Al
yycwrangler is offline   Reply With Quote Quick reply to this message
Unread 01-10-2015, 06:15 PM   #2
goodwrenchdave
Subbed as I also really need something simple/cheap (sorta) and easily removable.
goodwrenchdave is online now   Reply With Quote Quick reply to this message
Unread 01-10-2015, 06:50 PM   #3
reichard117
reichard117's Avatar
2014 JK Wrangler
My kayak rack will be a pool noodle on the top and some paracord to the front bumper and hitch
Originally Posted by Maertz View Post
In that case go for gold jeffy.
'14 JK - My JK Build
'00 XJ - Currently unwanted project
Follow me on Instagram - thereich
reichard117 is offline   Reply With Quote Quick reply to this message
Unread 01-10-2015, 10:00 PM   #4
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
Like this....?
The only thing slightly different that I did was to use some pipe insulation across the windshield. It is precut into a C-cross section. So it easily stays on top of the windshield. The Orange kayak (Jackson Rogue 9) weighs only 40 lbs. The Yellow one (Jackson sit-on-top) weighs about 55 lbs. But that is distributed across the roll bar, also.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Fox 2.0 shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
"Boing Clash Boom!" - Dada Life
HappyTrails is offline   Reply With Quote Quick reply to this message
Unread 01-10-2015, 10:55 PM   #5
G8torstang
2014 JK Wrangler
Yeah, screw that paying 3 figures for a rack! I use pool noodles and 2 ratchet straps and it has worked for single or tandem kayaks.
G8torstang is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 06:56 AM   #6
reichard117
2014 JK Wrangler
Originally Posted by HappyTrails View Post
Like this....?
Haha yes like that! :high five: Mine is around 50 so I'm not too worried.
