Signs of Bad Water Pump - JeepForum.com
post #1 of 4 Old 06-08-2012, 07:16 AM Thread Starter
lostsock
What are the signs/symptoms of a bad water pump?
lostsock is offline
post #2 of 4 Old 06-08-2012, 07:21 AM
ronjenx
ronjenx's Avatar
Weeping fluid under the pump in the area of the shaft bearing; noise from the pump when it's running; wobbling pulley when you check it with belt tension removed; continued overheating when you have eliminated other causes; (to name a few).
ronjenx is online now
post #3 of 4 Old 06-08-2012, 07:22 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
With the engine off, try to rock the water pump pulley from side to side...if it moves, the bearings are worn out. Overheating of the engine (duh) and leaking from the pump.
Edit: Ron wins
Mol is offline
post #4 of 4 Old 06-08-2012, 07:32 AM
JIMBOX
If there's a leak at the bottom (lower left), then the pump may be OK, but the gasket is failing at the two lower 10mm bolts--
If not that, then the above post info is righton-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
Water pump. Drix YJ Wrangler Technical Forum 0 07-02-2011 03:26 PM
4.0 Water Pump Pulley Seized onto water pump grAmit TJ Wrangler Technical Forum 9 09-09-2009 04:17 PM
Signs of Fuel Pump Failure? Sambox YJ Wrangler Technical Forum 15 06-05-2009 05:48 PM
Water pump??? jhaycock13 TJ Wrangler Technical Forum 8 10-28-2008 09:30 PM
I think I want a water pump... kaybone TJ Wrangler Technical Forum 12 01-16-2008 05:39 PM
