Side steps for 2014 JK - JeepForum.com
post #1 of 11 Old 10-08-2013, 07:40 PM Thread Starter
kevin101
2014 JK Wrangler
Hi everyone, I've been a member here for a little bit but never posted until today.
My question is:
I just picked up a 2014 JK. The color is dune and it has a soft top. I'm looking to get a decent looking set of side steps for it and I was wondering what kinds are out there. I'e found these http://www.quadratec.com/products/12117_400_07.htm but I didn't know how these work out.
Any other suggestions anyone might have would be appreciated.
kevin101 is offline
post #2 of 11 Old 10-08-2013, 09:36 PM
WhiteRavenRR
Are you looking for just a step or are you looking for something more functional for off road? Those will serve the purpose of a step but that's about it.
If off road use then I recommend something a little more robust from ACE, LoD, Poison Spyder, etc.
WhiteRavenRR is offline
post #3 of 11 Old 10-08-2013, 09:46 PM Thread Starter
kevin101
2014 JK Wrangler
It'll be a step only. I don't plan on doing any offroading at this time other than a little mud.
kevin101 is offline
post #4 of 11 Old 10-09-2013, 01:48 PM
jeepsnmopars
ACE are simple to install, inexpensive, function well as a step and will protect the side of your vehicle's rocker panels if you ever find yourself a little too close to anything offroad or not.
1992 Sahara "the dull chain saw"
2012 JK 2dr
1968 Barracuda Formula S
jeepsnmopars is offline
post #5 of 11 Old 10-09-2013, 03:55 PM Thread Starter
kevin101
2014 JK Wrangler
Cool thanks, I'll check them out.
kevin101 is offline
post #6 of 11 Old 10-09-2013, 06:36 PM
nhfd01
Aries makes a decent step
nhfd01 is offline
post #7 of 11 Old 10-09-2013, 07:48 PM
Mfrancis
2014 JK Wrangler
Are the ACE steps the only steps that are compatible with the Rubicon rockers?
Black 2014 JKU Sport S, 6 speed manual, 3.73 rear end, 2.5" AEV Dualsport XT w/ Bilstein 5100s, 255/75/17 Goodyear Wrangler A/T, Rubicon rock rails, front grill mesh mod, Jeep door sill guards, matte black Jeep grill emblem, matte black exhaust, Synrgy upper and lower bolt swap(highly recommend), tires pending...
Mfrancis is offline
post #8 of 11 Old 10-10-2013, 06:35 PM
73azbronco
I have a set of ORFab rocker panel bars on order, anyone else use these?
My criteria was no welding, no drilling through frame, had to incorporate body seem, did NOT drill into body (other than make holes already there bigger).
http://www.orfab.com/details.php?App...7&Title=ROCKER PANEL W/ BAR - JK WRANGLER 2-DOOR &Active=Yes
I previously tried to mount a set of smittybuilt rock sliders, and even though the website, online instructions said it would work with a stock Rubicon, you had to remove the rubi rail, and it did not protect the lower body seem from impact, which the ORfab does (yes, even though the rail still has to be removed, but it protects the body seem line, and made in AZ).
73azbronco is offline
post #9 of 11 Old 10-10-2013, 06:57 PM
Deuskid
I bought a pair of rubi rails that were take offs [I have an S]... and a pair of ace rails.
That combo meets your criteria.
John
Deuskid is offline
post #10 of 11 Old 10-10-2013, 07:07 PM
73azbronco
I looked at those as well, but went orfab, thanks.
post #11 of 11 Old 10-11-2013, 07:15 PM
jcgribks
I got a set of 4" oval ones from Rugged Ridge. They have the black crinkle finish, are the all straight type and go from fender flair to fender flair. I've had them on for over a year and they still look great.
jcgribks is offline
