Side Rear Window issues on 2012 soft top - Page 2 - JeepForum.com
post #16 of 20 Old 07-30-2013, 08:34 PM
gr8gazou
Wow. Thanks. I was having the same Problem with my 2013.
gr8gazou is offline
post #17 of 20 Old 07-30-2013, 11:16 PM
PappyRamey
The dealer apparently had the top down on mine at some point before I bought it and didn't care how they put it back together. Two days after purchase I drive from coastal Georgia to northern Alberta. Somewhere in Iowa, hit at a good wind and the leading edge of the rear window panel popped out. I thought the top was coming off! Anyway, thanks to this very forum I found out what I couldn't find anywhere else. Slip the "L" into the channel and close the door! Man I felt stupid all over again.
PappyRamey is offline
post #18 of 20 Old 08-05-2013, 11:52 AM
Afmcronnie
Start the zipper about 2 inches, then put the channel in, THEN zip it in. I put the bottom in last. Start the top of the channel first.
Afmcronnie is offline
post #19 of 20 Old 06-22-2014, 08:28 PM
Grouchy187
Hate to resurrect an old thread but as a new JKU owner, this thread was really helpful, and might help others. I thought the window L just sat against the rear plastic door frame and the door closed and kept it in place. After seeing this thread, I realize that the L is supposed to be tucked INTO the plastic door frame from the front. Now the window gets a much better seat in place from top to bottom, leaving only a very very tiny opening near the top.
Grouchy187 is offline
post #20 of 20 Old 04-14-2015, 09:37 AM
lakemartin302
Love this thread. Hate to say I have had my jeep 3 years and no problems until I hit 75 and passing tractor trailers. Searched everywhere and even went to a Jeep dealership in the city I moved to with no luck. I was able to get one side in like this, but the other I may have to take the top back down and restretch it some. I cleaned and lubed the zippers, but can't get the second side zipped more than about a foot after I tuck it INTO the slot between the door and vertical soft top support column. Wish I had seen this thread before.
lakemartin302 is offline
issues , problems , soft top problems , window instalation , windows
Jk 2012. Rear window!! Wrangler44 JK Wrangler Technical Forum 5 06-05-2012 04:17 PM
2012 jk soft top side window question 2dr Wrangler44 JK Wrangler Technical Forum 6 06-03-2012 04:19 PM
where to get side window for soft top JeepCEO JK Wrangler Technical Forum 9 12-06-2010 11:58 PM
Issues with Soft Top Rear window mjlvd3 TJ Wrangler Technical Forum 17 06-06-2008 09:35 PM
storage solution for side panels and rear window of my soft top? jskidder JK Wrangler Technical Forum 8 03-14-2007 08:05 PM
