Should I install new bumper & new winch together? - Page 2 - JeepForum.com
post #16 of 21 Old 05-10-2014, 10:34 AM
JohnnyWhitehead
2011 JK Wrangler
I was actually looking at the mid length crusader.
Rubicons have an electronic sway bar disconnect.
GEAUX TIGERS!!!!
JohnnyWhitehead is offline
post #17 of 21 Old 05-10-2014, 12:05 PM Thread Starter
nathanmilsaps
The pictures on the jcr website show a recessed bumper.
I have a rubicon and mine works fine.
I bought the JCR lower skid plate also though to protect the disconnect.
nathanmilsaps is offline
post #18 of 21 Old 05-11-2014, 08:58 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Originally Posted by nathanmilsaps View Post
The instructions on the JCR website say the opposite. Says to install them all together.
I'm sure it's just a matter of preference with this bumper.
The people who make the bumper also make the instructions. SO it quite likely the instructions they provide are the correct method.
I have a novel idea. Rather than ask a forum and wade through a huge debate - by the time the forum has cooled, the bumper could have been installed taken off and reinstalled twice - by following the directions.
But direction following is a matter of preference...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #19 of 21 Old 05-11-2014, 09:50 PM
wilgeno
Bug-Out!
wilgeno's Avatar
I just installed my Warn Elite bumper last weekend. If it were not for my ATV/Motorcycle lift I would not have got it mounted on my own. Using an ATV lift or floor jack of some type (with wood blocking) can help with holding the bumper up while you get the first bolts in place.
TeraFlexed '13 Commando Green JKU Black Hardtop roll'n on 35's!
Bug-Out!
I don't always go topless, but when I do I go Commando!
wilgeno is offline
post #20 of 21 Old 05-12-2014, 09:19 AM Thread Starter
nathanmilsaps
Wow. Thanks for the input.
Actually, since you are posting on my old thread from back in March. I could have installed per directions from the manufacturer's website, taken it off, installed per directions from the manufacturer's rep, taken it off, installed per directions in my own head, taken it off, had you come over and installed it for me.
I guess assuming is a matter of preference for you...
No matter, it's INSTALLED by now.
post #21 of 21 Old 05-13-2014, 04:33 PM
67alecto
2014 JK Wrangler
The instructions for the Rugged Ridge XHD say the same, and it's lies. LIES! I tell you.
Installed together, you're looking at around 170 lbs to man-handle onto the frame. I did that, and managed to get it on by myself (thanks farmer's carry/deadlifts!).
However, I later found out that the ground wire - conveniently located on the bottom of the winch between the bumper and the winch itself (/sarcasm) - came loose.
Resigned to taking it off again, I got under the jeep and then noticed that all of the bolts for the winch were easily accessible. As a result, I loosened all of the bolts, and then I had my 11-year old son hold up a corner while I reattached the ground wire.
Long story short, walk through the instructions without actually installing it and decide if you have to attach it before or if it would be easier to do it after - especially if you're working solo.
Current: 2014 Flame Red Rubicon Unlimited.
Old: 2007 Steel Blue Sahara Unlimited
67alecto is offline
