Should I go 35s or 37s KM2s on my JK rubi axles? - JeepForum.com
post #1 of 9 Old 08-13-2009, 11:31 PM Thread Starter
TX-WJ
TX-WJ's Avatar
OK, so, here's my question; I own an '04 WJ, bear with me here, I've wheeled it for a couple of years on a 2.75" lift and 32s. Last winter, I snapped a rear shaft (D44 aluminum rear end with an Aussie lunchbox locker) and decided it was time to move on with a better drivetrain.
At the time, the JK rubi 44s could be still had for cheap, so I decided to go that route with the intention of running 35s after going to a 6" LA lift; yes, fenders will be cut .
The past couple of months, I've been working on the axles to get them ready to mount under my dubjay; now the front is done (did the EVO gussets/skids and sleeves, as well as a RK truss) with the exception of gears. The rear will be trussed and eventually, will chromolly both F and R.
The WJ is obviously a heavy Jeep, but I'm sure not incredibly more than a 4 door JK (I may be wrong there though ); so for those of you (particularly 4 door JK owners) who have run 35s and then moved to 37s, did you suddenly find yourselves breaking down at the trail all the time?
I know that's a very generic question, but just trying to gauge some concepts that my help me decide whether I ought to stick to 35s or go all the way and get 37s and "be done with it"
FWIW, I think the KM2s do run a little smaller then other MTs .
couple'a pics.
David.
(steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd JK Rubi D44s
TX-WJ is offline
post #2 of 9 Old 08-14-2009, 08:33 AM
N2rock
N2rock's Avatar
K-Rocks pictures Damn shame they closed the place.
With the setup you're talking about- the D44's with gussets, sleeves, trusses, chromo's. I don't think you'll have any problems running 37's. And that is going to be one awesome rig!
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #3 of 9 Old 08-14-2009, 10:02 AM
AlterEgo
You already have braces, gussets, and sleeves. Since you still need gears, go for the 37s.
Gary Greenway - KD8NHC
08 4 Door Rubicon
Member of Two Trackers 4wd Club
Great Lakes Four Wheel Drive Association
United Four Wheel Drive Associations
AlterEgo is offline
post #4 of 9 Old 08-14-2009, 12:48 PM
PLAN D
hey tx-wj, i also have a wj with a jk rubi rear 44 and have bent two axle flanges. I'm running 33's with stock shafts, do you think upgrading to cromolly shafts will prevent this?
PLAN D is offline
post #5 of 9 Old 08-14-2009, 12:57 PM Thread Starter
TX-WJ
TX-WJ's Avatar
Oh no!, not what I wanted to hear ; I dunno, that's why Im trying to ask the JK guys see what they have to say..... maybe I oughtta stick to 35s .
David.
TX-WJ is offline
post #6 of 9 Old 08-14-2009, 12:58 PM Thread Starter
TX-WJ
TX-WJ's Avatar
Yup, K-rocks was the best, too bad is gone now !
David.
TX-WJ is offline
post #7 of 9 Old 08-14-2009, 01:06 PM
USAFRecon
37's on a Dub Jay I think I may need a towel...
USAFRecon is offline
post #8 of 9 Old 08-14-2009, 01:17 PM
N2rock
N2rock's Avatar
Wow- is the WJ that much heavier than the JK Unlimited?
N2rock is offline
post #9 of 9 Old 08-14-2009, 05:21 PM Thread Starter
TX-WJ
TX-WJ's Avatar
JK unlimited (Rubicon) curb weight: 4,340 lb source
WJ Limited 4WD (4.7): 4,147 lb source
What gives?
Ninja edit:
JK unlimited (Rubicon) Torque: 240 ftlb @ 4,000 rpm
WJ 4.7 Torque: 295 ftlb @ 3,200 rpm
TX-WJ is offline
JK Rubi Axles in a TJ? MillerTimeTJ TJ Wrangler Technical Forum 6 02-08-2008 11:17 AM
New Rubi Axles for My TJ what else do I need? Yellow TJ TJ Wrangler Technical Forum 9 11-30-2007 12:50 AM
Need Rubi axles and wheels TJamz TJ Wrangler Technical Forum 7 11-07-2007 11:38 AM
rubi axles on an x?? mansfieldjeep TJ Wrangler Technical Forum 5 08-25-2006 03:35 PM
? on rubi axles NOTQUITEMUSASHI TJ Wrangler Technical Forum 17 07-01-2005 07:58 PM
