Shocks - Stock or Upgrade - Page 2 - JeepForum.com
post #16 of 20 Old 11-22-2010, 10:52 AM
asknight
Originally Posted by stubbornspot View Post
What if I'm running just the rear bracket for a little while and then get the adjustable trackbar in maybe a month or two? Would that be too long? I mean how long before it starts causing problem?
It all depends on how much you flex your suspension during that time and the age of the OEM rubber bushings. As they age, they aren't as pliable and tend to not return to original dimensions after being compressed in a certain position for any length of time. You'll probably be OK.
From the sounds of it a 2.5 inch lift puts you out of alignment by about .25"-.5" So if the rear bracket corrects half of that, its not too far off for the time being.
A 2.5" lift will put your front axle out the drivers side ~1/2" and your rear axle ~1/2" out the passenger side. That's 1" of misalignment F to R.
Sorry for the huge number of questions. Always been a DIY type person, just never with my cars. The Jeep has inspired me to learn how to do some new things.
No worries! That's why we're here on the forum to learn and advise. I'm not an expert by any means, but my TJ has been kinda problematic so I've been forced to learn quite a bit when I'd rather be driving it.
asknight is offline
post #17 of 20 Old 04-23-2012, 06:25 PM
4DFUN
Don't know if I messed it, but I am trying to figure out the stock shock length, extended.
Thanks
4DFUN is offline
post #18 of 20 Old 04-23-2012, 06:47 PM
ncb
Thanks
http://www.jeepforum.com/forum/f96/o...ength-1266993/
ncb is offline
post #19 of 20 Old 04-27-2012, 11:57 PM
4DFUN
Thanks
4DFUN is offline
post #20 of 20 Old 11-12-2012, 12:45 PM
ISLANDERQUEEN
2010 JK Wrangler
I have gone thru 3 tires, working on another 2 because of unusual wear. Dealership says they can't find anything wrong so I checked w/a tire co and they say shocks r bad. I only have 28k miles on my Jeep Wrangler 4dr. (2010) Should I replace shocks w RS9000XL or go w/ what dealership wants to put on?
ISLANDERQUEEN is offline
bb , budget boost , jk , shocks
Upgrade Shocks??? kurtjohn JK Wrangler Technical Forum 2 04-23-2009 11:41 PM
Stock shocks vs teraflex 9550 shocks? Dhall09 JK Wrangler Technical Forum 6 02-23-2009 09:27 AM
terra 2.5bb shocks vs rubi stock shocks TrickyDogShow JK Wrangler Technical Forum 1 08-26-2007 05:02 PM
Upgrade stock shocks... GoldenP51 TJ Wrangler Technical Forum 2 05-21-2006 04:53 PM
