shock question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > shock question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender Flares
Unread 11-20-2009, 03:45 PM   #1
hdrider
shock question
I put a OME 2" lift on my jeep (more like 2.5") and then I installed a 1.75" coil spacer and 35" tires. Right at a 4"lift.
Well,, now my shocks don't have much UP travel left,, maybe 1.5". So I see that OME has a long travel shock,,, does anyone know if it would be a cure for my situation? Then what,,, would I need longer springs also? Will it ever end... I know,,, do it right the first time,,, but that didn't happen.
hdrider is offline   Reply With Quote
Unread 11-20-2009, 04:27 PM   #2
gsaxe
can't help ya...but i'd love to know if the ome ride is all its cracked up to be?
gsaxe is offline   Reply With Quote
Unread 11-20-2009, 04:47 PM   #3
wilywillie
wilywillie's Avatar
Same here, but I've heard only good things about them...
wilywillie is offline   Reply With Quote
Unread 11-20-2009, 05:10 PM   #4
hdrider
I like the ride,, I have not been in that many jeeps to compare it to but if I find out that the LT OME shocks will work with my situation I will have no reservations about buying them instead of another brand.
Unread 11-20-2009, 05:28 PM   #5
USAntigoon
Retired from Forum
I have an OME lift and got their NitroChargers installed as well.. Their shocks are tuned for this kind of lift.. Keep in mind that spring frequency is a contributing factor in the ride Quality.. I just love the ride I have..
USAntigoon is offline   Reply With Quote
Unread 11-20-2009, 05:40 PM   #6
JLC08JK
What was I thinking?
JLC08JK's Avatar
Yes! you need longer shocks. If you want to go with OME then just give them a call and tell them what you have!
They'll tell you the options!!
Thats my story, i'm stickin' to it!!!
Jim
Jim's Jeep; THE OBSESSION LIVES ON!
Jim's JK D44 Rear Axle Build
99% of Your JK Questions will be Answered Here
JK F.A.Q./WILL IT RUB and Popular Threads
Protect Our Rights to Freedom and the Environment
Visit the EnviroBeat
JLC08JK is offline   Reply With Quote
Unread 11-20-2009, 05:42 PM   #7
hdrider
I aggree,, the shocks are great that come with the lift. But my problem is that I added another 1.75 coil lift that depleated my upward shock travel.
I'm concidering the OME N67L and N66L as a replacement. I just want to make sure they will fix my lack of upward travel I have now.
Unread 11-20-2009, 06:03 PM   #8
USAntigoon
Retired from Forum
Got it...Well JLC08JK gave the right advice... Call the OME guys, they know the shock travel details for sure...
