Shock Adapters - How Tall? - JeepForum.com
post #1 of 5 Old 09-13-2008, 09:19 PM Thread Starter
scrogg
I know that there are several of you out there that have purchased a budget boost that came with adapters for the shocks in lieu of buying new shocks. Does anyon who has them, or even who doesn't, that knows how tall they are?
For example, the 2.5" TeraFlex BB that has them, did they compensate for the full 2.5" of height gain? How sturdy/strong would you say they are? Do you trust them for off roading?
scrogg is offline
post #2 of 5 Old 09-14-2008, 12:56 PM
SoCalJK
SoCalJK's Avatar
I have the RC budget boost and the shock extenders were the full 2.5 inches. I've done a fair amount of off roading including the Jeep Jamboree with them and had no problems at all. Very happy with the kit. When I've the cash I'll put on other shocks and dump the extensions.
2007 Sahara Unlimited
4x4, Auto, Jeep Green, Tow Package, Soft top, 3 inch spring lift, MBRP Catback
SoCalJK is offline
post #3 of 5 Old 09-14-2008, 06:41 PM
Prot
Prot's Avatar
2014 JK Wrangler
Unless you are on a very tight budget, get better shocks. Look at the size of the stockers compared to any decent aftermarket ones.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #4 of 5 Old 09-14-2008, 06:48 PM
BirdsFanVa
BirdsFanVa's Avatar
x2.
If there is any week link in the Tera BB, it is the rear shock extenders IMO.
07 Black Sahara Unlimited 2.5" Skyjacker suspension lift, RE quick discos, 3/4" front spacers, 16x8 soft 8's, BFG 33x12.50's MT's, Shrockworks rock rails. Bulldog rock crawler winch bumper, Warn M8000 and lot's of armor! (Mine)
08 Redrock X Unlimited (Hers)
____________________________________________
Driving a Jeep to work makes it feel like you're going camping!
BirdsFanVa is offline
post #5 of 5 Old 09-14-2008, 07:10 PM Thread Starter
scrogg
I am mostly concerned about the front. Allow me to explain (takes a deep breath)...
I have a 4" lift along with a set of ACOS Pros up front that give me an overall 7.5" of suspension lift from the stock height. When one side of the front axle is drooped/extended I have to limit the droop to point where the shock gets pulled into the frame. I could still go another 3.5" until I get limited by the sway bar and link, which is where I wanna be. The further vertically down that one side goes, the further under the vehicle it goes as well. This then pulls the shock body into the frame and would bend it if not limited.
I am thinking that if I can lower the top of the shock, then at the point of droop when the shock body would have hit the frame (prior to being lowered) it would now be lower than the frame and allow me to get that extra 3.5" of available droop before being limited by the sway bar and link.
If that made any sense then tell me what ya'll think. And if you have any other ideas please share. I could always move the lower factory mount outward about 3/4", but I was hoping to not have to pay someone to cut and weld.
(*edit)
Not sure if this will matter but if I remove the shock and disconnect the sway bar, then the axle will droop well beyond what I was able to measure in the driveway using jack stands and removing the tire/wheel. The limit there would be however far the control arms would let it drop. Of course, the brake line and ABS wiring would be ripped apart by then.
scrogg is offline
Shock Adapters or New Shocks for Lift? JHamer85 JK Wrangler Technical Forum 12 04-04-2016 01:04 PM
how tall is my TJ? PanicAtTheKmart TJ Wrangler Technical Forum 6 11-07-2009 03:42 AM
are you tall ??? $300xjwith250k YJ Wrangler Technical Forum 11 06-14-2008 02:59 PM
How tall is your YJ? jeepfunatic YJ Wrangler Technical Forum 15 04-06-2008 08:12 AM
too tall!!!!! jmoore YJ Wrangler Technical Forum 1 11-10-2001 09:40 AM
