Shifter Problems Anyone? - JeepForum.com
post #1 of 10 Old 07-10-2010, 07:02 AM Thread Starter
PSYCH0
PSYCH0's Avatar
2009 JK Wrangler
Had shifter problems this week... It's an automatic and it won't go into any gear... when you try to put it in park it grinds...
the 4x4 lever just floats back and forth as well...
Anyone have this issue?
2009 Jeep Wrangler JK, 2-Door, Soft Top, Automatic, Black Procomp Aluminum Wheels with 315x75R16 Goodyear Wrangler Duratracs, 2" Black Diamond Lift, JKS Adjustable Track Bars, Smittybilt Rock Rails
PSYCH0 is offline
post #2 of 10 Old 07-10-2010, 07:40 AM
mandalayjim
Sounds like a warranty issue with the transfer case. Had mine replaced because it was very diffulcult to engage the trandfer case after towing with the motorhome.
mandalayjim is offline
post #3 of 10 Old 07-10-2010, 08:09 AM Thread Starter
PSYCH0
PSYCH0's Avatar
2009 JK Wrangler
Dealer called today and said its a bushing that went bad in the shifter... but why would both the gear shifter and 4x4 shifter not work... are they connected?
PSYCH0 is offline
post #4 of 10 Old 07-10-2010, 08:15 AM
ronjenx
ronjenx's Avatar
With the t-case being stuck in neutral, the transmission is free to spin because it is no longer connected to the drive train. That's why it grinds when you try to put it in park.
ronjenx is online now
post #5 of 10 Old 07-10-2010, 08:26 AM Thread Starter
PSYCH0
PSYCH0's Avatar
2009 JK Wrangler
That part I understand... but why the 4x4 shifter is free flowing back and forth I dont...
PSYCH0 is offline
post #6 of 10 Old 07-10-2010, 08:52 AM
azxr
2009 JK Wrangler
Because the cheap 25 cents plastic piece they use to connect the cable to the transfer case. Very common for it to break; most likely when it is the most inconvenient.
Do a search and you will see it is very common.
2009 Stone White Unlimited Rubicon - MyGIG, Hardtop, Auto, Remote Start.
azxr is offline
post #7 of 10 Old 07-10-2010, 08:56 AM
ronjenx
ronjenx's Avatar
OK.
I was answering your question regarding why BOTH shifters don't work.
post #8 of 10 Old 07-10-2010, 09:06 AM Thread Starter
PSYCH0
PSYCH0's Avatar
2009 JK Wrangler
OK.
OK now I understand! Thanks!
PSYCH0 is offline
post #9 of 10 Old 07-10-2010, 09:13 AM
owenswj
Just got mine out of the shop for the same issue. A cheap plastic piece broke. They had to ziptie it for the time being until the connector came in. It worked fine with the ziptie. Maybe you could try that?
owenswj is offline
post #10 of 10 Old 07-10-2010, 09:30 AM Thread Starter
PSYCH0
PSYCH0's Avatar
2009 JK Wrangler
Had it towed to the dealer on Friday... they can have it there til they get the part in... hopefully Monday... let them do the recalls on it too while it's there...
PSYCH0 is offline
Wrangler , JK Wrangler , Shifter , Automatic , Transfercase , Malfunction
problems with shifter mountainb29 JK Wrangler Technical Forum 1 07-08-2010 10:24 AM
Shifter problems Rubicon153 TJ Wrangler Technical Forum 3 09-11-2007 05:57 PM
TC Shifter Problems JeepOX TJ Wrangler Technical Forum 5 05-24-2007 07:12 AM
Shifter Problems after BL and MML.... colbyB25 TJ Wrangler Technical Forum 10 01-18-2006 12:36 PM
Shifter Problems after bl and mml? aaronswb2 TJ Wrangler Technical Forum 2 10-03-2005 08:16 AM
