Shifter console light - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Shifter console light
The Boss is away but Erin is here to STAY with a F.Y.S. SaIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 01-31-2015, 07:16 AM   #1
bendocko
2013 Sahara shifter light on console burnt out. What is the quick fix here? Fuse or bulb replacement? If bulb, does anyone havea "diy" guide
thanks
bendocko is offline   Reply With Quote Quick reply to this message
Unread 02-02-2015, 09:01 AM   #2
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Not sure about the 13, but when I looked into changing my console lights on my 08 I found they were all soldered LEDs on the back of the control panel circuit board. I hope yours is still under warranty, if not, take a look at the instructions available either through the service manual (CD) or at one of the kits to change the color of your lighting like I did.
Or, is the light you are talking about at the shifter itself? If so, then just remove the shifter cover and it is probably on a circuit board behind the cover.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote Quick reply to this message
Unread 02-02-2015, 03:28 PM   #3
Mlarv
2014 JK Wrangler
I have a 14 Freedom edition and the auto shifter lights do not light either. I am talking the ones that are marked PRND I stopped at the dealer where I bought it and they said they do not light up. So if these are the ones you are talking about then from what I was told they don't. If they are supposed to then I was told incorrectly.
What Would Scooby Do?
Mlarv is offline   Reply With Quote Quick reply to this message
Unread 02-02-2015, 03:50 PM   #4
JIMBOX
If you're talking about the auto shifter lights ON THE DASH--
They have to light/w a SQ around whichever gear you're in-
Mine do, bright and clear, course, that's with the old horse and buggy 42RLE 4spd tranny-
Whatever-
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote Quick reply to this message
Unread 02-02-2015, 06:12 PM   #5
bendocko
These are the lights for the PRND. Last oil change dealersip quoted "significant" time to replace? Cant imagine that difficult. May try another dealership. Didn't see anything on you tube for the 13
Unread 04-18-2015, 11:37 PM   #6
kappaknight
Wow - there really are a TON of threads for this online. I know b/c I've been trying to replace mine, and none of these threads have the solution.
2013 Commando Green JKUR
/_|o[____]o
[1---L-OllllllO-
()_)()_)=°°=)_)
kappaknight is offline   Reply With Quote Quick reply to this message
