Shifter Boot Retainer - JeepForum.com
post #1 of 6 Old 06-01-2011, 07:49 PM Thread Starter
WVMUDDIN
Any suggestions on fixing the factory plastic shifting boot retainer on my 08 Rubicon manual shift. The faux plastic rivets looks as if they are glued down to the consol panel holding the rubber boot in the pre drilled holes on the boot itself. 4 of these faux rivets starting at the cup holder going around toward the passenger side broke loose and my boot comes out each time I shift to first. I feel like I'm missing something simple.
WVMUDDIN is offline
post #2 of 6 Old 06-01-2011, 08:25 PM
Charles
2017 WK
Epoxy. There is a vendor around here that sells a one that actually screws down, but Epoxy will do it. I used Epoxy on my 07.
2017 TrailHawk Hemi, Everything but the TV's.
Charles is offline
post #3 of 6 Old 06-01-2011, 08:57 PM
wilywillie
The black boot and the bottom plate are all one piece. IIRC, there are 2 straight pull clips in the rear, and 2 slide clips in the front.
I thought mine was more mechanical, so I busted it the first time I took it off. ~$20 at the dealer.
....or epoxy!
I'm just here for the gasoline. --Max
wilywillie is offline
post #4 of 6 Old 06-01-2011, 09:28 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Here is a similar thread and this guy drilled them out and added real screws > http://www.jeepforum.com/forum/f96/b...3/#post7148271
Jim
JLC08JK is offline
post #5 of 6 Old 08-29-2011, 08:18 AM
87_YJ
Fixed mine this way this weekend.
**SOLD**
'87 Yj
258 I-6 4.2L
Holley 390 cfm 4bbl
Offenhauser Intake
33x12.50 Mastercraft MT's
87_YJ is offline
post #6 of 6 Old 08-29-2011, 01:13 PM
2himyaz
This must be a 2008 thing. My 08 did the same thing. I like the idea of the screws it doesn't look too bad either.
2himyaz is offline
Shifter boot retainer? TJftw TJ Wrangler Technical Forum 10 03-09-2012 10:46 PM
Part number for shift boot retainer ring? bottlerocket91 TJ Wrangler Technical Forum 4 12-27-2010 11:38 AM
Shifter Retainer Oil Seal? Buttersmud YJ Wrangler Technical Forum 1 11-21-2010 12:23 PM
Gear Shifter Boot Plastic Retainer 200 TJ GIXMAN TJ Wrangler Technical Forum 3 02-05-2010 12:36 PM
odd question about inner shift boot retainer langston.4 TJ Wrangler Technical Forum 3 10-01-2006 09:21 PM
