SERVICE BULLETIN NUMBER: 06-001-13 2011 - 2013 JK Clutch Squeak - JeepForum.com
post #1 of 6 Old 08-05-2013, 09:07 AM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
FYI – Ignore if not interested
GROUP: Clutch
DATE: July 30, 2013
SUBJECT:
Squeak When Depressing The Clutch
OVERVIEW:
This bulletin involves lubricating the clutch pedal return spring stop.
MODELS:
2011 - 2013 JK Wrangler
NOTE: This bulletin applies to vehicles built on or before May 31, 2013 (MDH
0531XX) equipped with a manual transmission (Sales Code DEH).
SYMPTOM/CONDITION:
Squeak from under the dash when depressing or letting go of the clutch pedal.
JeepCares is online now
post #2 of 6 Old 02-25-2014, 02:46 PM
bayoumade
2011 JK Wrangler
service bulletin for clutch
this tsb u posted seems to refer to the noice of the clutch originating from inside the vehicle. Mine is loudest if u are outside when the clutch is depressed. its audible. was yours audible outside as well?
bayoumade is offline
post #3 of 6 Old 02-25-2014, 02:47 PM
bayoumade
2011 JK Wrangler
Did this action resolve the issue?
post #4 of 6 Old 07-03-2014, 12:59 PM
bayoumade
2011 JK Wrangler
clutch tech bulletin
I dont see how lubricating alone is a long term fix. lubes evaporate. There's a reason the cable is squeaking. lube is a cover up. how often do i need to keep re-lubing?? thats not feasible. you can hear from 20 feet away from the vehicle as it drives off. u hear the driver depress and release the pedal.
post #5 of 6 Old 07-03-2014, 01:01 PM
bayoumade
2011 JK Wrangler
oh and in answer to the question of did it resolve the issue. No it didnt the dealership stated they lubed it. and with in a few days it was back. hence my post that its NOT a correction its a band aid.
post #6 of 6 Old 07-04-2014, 11:55 PM
Moezer
2015 JK Wrangler
I have this problem with my 2014
Moezer is offline
