Service Bulletin ~ Fuel Spill Issue - JeepForum.com
post #1 of 120 Old 02-15-2011, 08:06 AM Thread Starter
kudah
Chrysler has released a service bulletin about the fuel spill issue in 2007 - 2008 JK's. They have extended the warranty on the inlet check valve. If you have this issue you get a free gas tank, if you have paid to have it fixed you can be re-imbursed for the repair. Submit your receipts directly to Chrysler. The extended warranty will show up on a VIP report if your vehicle is covered. The service bulletin is 14-001-11 ---- happy valentines day.
Robert
kudah is offline
post #2 of 120 Old 02-15-2011, 09:59 AM
ChicagoRod
Now if we can just get them to cover the TJ/LJ issue!
Rod
05' LJ
ChicagoRod is offline
post #3 of 120 Old 02-15-2011, 12:20 PM
aztec_doc
So does that mean it an official recall. or just a repair and is this nation wide?
aztec_doc is offline
post #4 of 120 Old 02-15-2011, 12:43 PM
ronjenx
ronjenx's Avatar
I'll have a copy of it later to post, unless someone beats me to it.
As far as I know, it's a TSB, not a recall.
The service manager at the local dealer said it's a free replacement for those who are having the problem; applicable to certain Jeeps; no time or mileage limit for the coverage.
ronjenx is online now
post #5 of 120 Old 02-15-2011, 04:16 PM Thread Starter
kudah
It is a service bulletin.. and they extended the warranty on certain '07 and '08 JK's. So not a recall.... on the VIP report that shows your warranty coverage there will be a new line that shows the unlimited / unlimited warranty on the inlet check valve... which is fixed by replacing the fuel tank. Completely covered by Chrysler... parts and labor.
Robert
kudah is offline
post #6 of 120 Old 02-15-2011, 05:02 PM
ronjenx
ronjenx's Avatar
Service Bulletin # 14-001-11, dated February 11, 2011.
Fuel Spit Back During Refueling (Unlimited Time and Mileage Warranty Extension)
Models:
2007 - 2008
Note:
This Extended Warranty Bulletin applies to vehicles equipped with 3.8L engine (sales code EGT) built between March 1, 2007 March 31, 2008.
Repair Procedure:
Replace the fuel tank,....
post #7 of 120 Old 02-15-2011, 07:33 PM
yoda13
Force Wheeler
yoda13's Avatar
awesome...mine has done this for almost two years
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Bilsteins, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, Delta replacement non-quadbar xenon headlamps, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, †John 3:16†
RIP Mrs. yoda13... My life is better for having had you in it and you made me a better man...I can't wait to see you again...I love you always and forever, and for all eternity
If you want to help the sport of off-roading, and protect your right to do so, please visit the
forum...
yoda13 is offline
post #8 of 120 Old 02-15-2011, 07:54 PM
MikeTHIS
I shall be making my appointment. I have an extended warranty anyhow (not sure if it was covered before) - but this is a huge headache for me as it happens every fuel up.
MikeTHIS is offline
post #9 of 120 Old 02-15-2011, 08:44 PM
aztec_doc
I also have the lifetime warranty and no it was not covered than. They told me they would write my name (bull) and keep an eye out for a recall. But I will be making a call tomorrow and having this taken care of asap. Who doesn't want new parts.
post #10 of 120 Old 02-16-2011, 01:09 AM
CCJ
I wonder if any 2010 2011 JK owners have this issue? I could have sworn I saw a brand new 2011 over fill yesterday at shell.
CCJ is offline
post #11 of 120 Old 02-16-2011, 06:32 AM
RescuedJK
This isnt entirely true...i was just at the dealer with my 07 jk with the same problem and they said mine didnt qualify cause of the build date...im gonna go to another dealer and see
01 xj 3" RC full kit. Rock sliders. Front n rear hitches. Black soft 8's on 31's
RescuedJK is offline
post #12 of 120 Old 02-16-2011, 06:33 AM
ChicagoRod
The 2009 and 2010 models probably do have the issue but there haven't been enough complaints yet to warrant issuing a TSB and they are both still under warranty. If you read Chrysler's findings after a NHTSA inquiry you will see that a 2011 redesign of the tank is coming.
http://www-odi.nhtsa.dot.gov/acms/do...032-42428P.pdf
Rod
05' LJ
post #13 of 120 Old 02-16-2011, 06:37 AM
mhizzle1341
I bought mine used, can I have this done?
mhizzle1341 is offline
post #14 of 120 Old 02-16-2011, 06:38 AM
RescuedJK
CAll the dealer...i just bought mine 07 used and I cant
post #15 of 120 Old 02-16-2011, 08:03 AM Thread Starter
kudah
does not matter if you bought the vehicle used or not. The have only said SOME JK's from '07 and '08 ... no clue what the criteria is being used to determine which vehicle are getting the warranty extended. Could be build date but it is not specific.
Robert
kudah is offline
2006 TJ throwout bearing Service Bulletin Steve98 TJ Wrangler Technical Forum 3 01-11-2013 08:00 AM
Technical Service Bulletin....... BringThaPain TJ Wrangler Technical Forum 0 08-27-2008 03:26 PM
Service bulletin 2004Jeeptj111 TJ Wrangler Technical Forum 4 02-24-2007 11:23 PM
jeep service bulletin marcolanza TJ Wrangler Technical Forum 2 05-16-2004 10:27 PM
Technical Service Bulletin (TSB) Outbounder TJ Wrangler Technical Forum 1 02-09-2003 11:22 AM
