Second Power Point - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Second Power Point
THE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great valueEngo winches available at www.rockridge4wd.com! Free shipp
Unread 06-25-2014, 09:25 PM   #1
dcramer63
2011 JK Wrangler
Second Power Point
I have a 2011 Sport that was only equipped with one 12v power outlet on the lower left of the dash. Can someone please provide the Mopar part number of the outlet and cap that fit on the right side (probably doesn't differ from the left). Thank you!
dcramer63 is offline   Reply With Quote
Unread 06-25-2014, 10:48 PM   #2
SoK66
1976 CJ5
Check moparpartsamerica.com. Should be able to pin it down off their site.
SoK66 is offline   Reply With Quote
Unread 06-26-2014, 06:43 AM   #3
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
My 08 has two, the left one is ignition switched and the right one is on all the time, but the only external difference is the right one is marked as having power on all the time but must connect into a different part of the wiring harness and has a different fuse.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 06-26-2014, 07:15 AM   #4
JIMBOX
I don't know whether or not you'd have trouble hooking it up though-they may have a harness plug (unused),behind the dash-or
Go to Kragens/O'briens/Zone and getta plug for $6.99 and "jumper it in to the existing plug, you'll probably have to cut the hole anyway-
I've done that on my jeep rear hardtop-the pwr plug comes/w red/black wires !
Good luck
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is online now   Reply With Quote
Unread 06-27-2014, 12:35 PM   #5
dcramer63
2011 JK Wrangler
For those interested, here are the Mopar part numbers:
Instrument Panel - CAP, POWER OUTLET
Part # 05026970AA
Instrument Panel - POWER OUTLET,
Part # 04793554AC
Jimbo, I also need a rear outlet, so will utilize your design work.
Thanks all!
