SEAT squeak! - JeepForum.com
post #1 of 5 Old 11-29-2011, 05:09 PM Thread Starter
Lammer
2011 JK Wrangler
SEAT squeak!
I have a seat squeak/creak, when the driver seat is in lowest position (no ratcheting up), regardless of distance from the steering wheel, I get a squeak/creak. It is most noticeable when I first get in and lean back, or when pulling away from a stop, turning a corner, or getting out of the Jeep. The Jeep is an 2011 Unlimited Sahara, new this past June. It's been in twice already for a fix, but no luck. First time, squeak was there as soon as I got the Jeep back, second time it was fine for a week, then returned. It appears they worked on the bolts to the floor.
I had a 2008 Unlimited Sahara, that had a sqeaky seat, but it was remedied the first time in. (They greased/oiled the F#*k under the seat, a bit messy but after a bit of a wipe down, it was great).
This Jeep is from a different dealership. I'm 200 lbs, 5'8". The sound goes away if I use the ratchet and up the seat to the first setting above the lowest. Problem seems is that over a period of a week or so, the seat eventually lowers and the squeak comes back.
Being a brand new Jeep, this annoys me, especially with it having been resolved in my 2008.
My question is, has anyone else had this problem? and what exactly did they do to fix it? I'm hoping to go in this third time and tell them what I want done, vs them guessing and not solving this irritant.
thanks in advance
Cheers!
Lammer
Lammer is offline
post #2 of 5 Old 11-29-2011, 05:14 PM
HappyTrails
"Seat Squeak"? If that's what you want to call it, ok then. I usually blame it on the dog. Sorry, couldn't resist.
It sounds like something under the seat is coming loose over time. Never had this problem...yet. If it is annoying enough, I'd remove the seat from the Jeep, and go over every bolt checking for looseness and tightening them all. Maybe a dab of superglue on the guilty bolt to keep it from loosening again.
HappyTrails is offline
post #3 of 5 Old 11-30-2011, 09:27 AM
hydrotechtx2
hydrotechtx2's Avatar
I had the same thing happen on my 2010 JK. I lightly greased the track and ran the seat back and forth several times...fixed the problem for now. I don't mind the little rattles and creaks in my JK but damn my seat was loud.
98 Sahara w/3.5 RE Superflex, RE adjustable control arms, 33x12.5x15 XTERRAINS, 15x10 Xtreme Alloys
2012 JK Rubicon Unlimited. 2012 JK Sport.
hydrotechtx2 is offline
post #4 of 5 Old 11-30-2011, 09:48 AM
5foot19
2016 JK Wrangler
I have a small squeak in my seat as well. I am hoping to look into the seat and brackets tomorrow.
5foot19 is offline
post #5 of 5 Old 11-30-2011, 10:56 AM
C2U5H
C2U5H's Avatar
My 2012 JK Rubi leather driver's seat squeaks with lateral movement. Annoying.
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
creak , problem , seat , squeak
Squeak Squeak coming from jeep when moving??? cyberiv TJ Wrangler Technical Forum 22 12-13-2012 02:46 PM
Squeak or whine from just above passenger seat ... davidsonlaw JK Wrangler Technical Forum 3 09-03-2011 08:29 PM
Squeak, Squeak, Squeak when cold... Schererj TJ Wrangler Technical Forum 2 12-17-2010 07:39 AM
Rear seat squeak jbn07x JK Wrangler Technical Forum 6 03-04-2009 09:56 AM
Sqeak squeak squeak. Annoying!!!! DrD TJ Wrangler Technical Forum 6 07-01-2006 11:32 AM
