Savvy JK Test Mule - Page 7 - JeepForum.com
post #91 of 295 Old 07-02-2012, 10:08 AM
Imped
Imped's Avatar
It sounds like those Currie steering links go through a similar heat treating process as your TJ tie rod, right Gerald? If that's the case, then that's the last linkage a JK owner would have to buy.
OlllllllO
IndyORV
Imped is online now
post #92 of 295 Old 07-02-2012, 10:59 AM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Yes, 4340 heat treated. I'm going to give it a go and beat it a little next weekend. They are having a grand opening of the Azusa Canyon Obstacle course on July 14th. I've been asked to attend so I will to support our OHV areas.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #93 of 295 Old 07-02-2012, 11:11 AM
geiman
Are all of the JK steering setups 4340, or was yours special? I was looking at it on Currie's site and there they claim it's 4130; we're looking at getting a JK in the somewhat near future, so I'm just curious. It's probably just nitpicking, but I certainly won't claim to be an expert in metallurgy.
geiman is offline
post #94 of 295 Old 07-02-2012, 01:41 PM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Ill verify with John but that is what I thought he told me after the first batch proven too brittle.
Like us on Facebook
Savvy is offline
post #95 of 295 Old 07-02-2012, 01:48 PM
mJUSTINm
Might need to go check out Azusa if I'm not busy! That place might finally be a good time (not a fan of mud).
-Justin
mJUSTINm is offline
post #96 of 295 Old 07-02-2012, 06:28 PM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Just finished programming the JKU with the AEV Procal and I really like the performance! I had to drive home from the shop to get the Procal and it ran like poop! Once I programmed the 4.88s it has fantastic performance again!
I've noticed the tranny takes a little bit to fluid up. So i'm watching this closely. I don't think I touch anything to do with that.
Like us on Facebook
Savvy is offline
post #97 of 295 Old 07-03-2012, 08:24 AM
MountainMan864
How come you didnt go 5.13s? Do you need a new power steering pump and box when going to the currie hydro assist?
MountainMan864 is offline
post #98 of 295 Old 07-03-2012, 09:10 AM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
No need for 5.13 in the 2012. The new 5 speed auto and new motor that provides plenty of power to be able to keep the 2012 in the right gear most of the time. We also like the larger pinion gear as we feel it is a stronger gear set.
PSC is working on a new bracket so we can replace the OEM pump with a higher performance one. A better pump is recommended as the OEM is a little bit slower than what i'm use to. Still the OEM pump works fine when off road and being able to turn makes navigating the rocks and obstacles much more fun!
I opted to send my steering box to PSC to be ported for hydro assist. It save $600-700 doing it this way. They put a new rear section the the OEM box.
The Currie axle is really close to ready for hydro assist. The brackets are alot stronger than stock so not as much work needs to be done to add hydro assist. The Currie HD steering is ready for HA with a bolt ram mount that makes to alignments a snap.
Like us on Facebook
Savvy is offline
post #99 of 295 Old 07-03-2012, 09:21 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
No need for 5.13 in the 2012? I wholeheartedly disagree, but won't argue with you. Surprising, given the rest of this build, unless this is planed to be a show rig only? But then pinion size wouldn't matter...which I wouldn't think to be an issue with a deeper gear set in a custom currie axle, in the first place...
Mol is offline
post #100 of 295 Old 07-03-2012, 10:24 AM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Agreed in a 2007-2011 you need the deeper gears but on 2012 you don't.
Unless you've driven a 12 with gearing you can't understand how much better these drive then the early JKs. This thing just peels out and we still like to drive 80mph. This rig will do everything but the Hammer trails. It is not a show queen. This is my only trail Jeep now. Everything is gone!
With a hi-pinion rear, you want the larger pinion and since this motor puts out 285 hp, it can break stuff. Unlike the anemic early models.
Like us on Facebook
Savvy is offline
post #101 of 295 Old 07-03-2012, 10:28 AM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
So here how the JK sits with a Currie 4" suspenion lift. I imagine it will settle a bit as I only have 50 mile s on it. Also need to install the bumpers, rockers and Falken 37" tires.
Like us on Facebook
Savvy is offline
post #102 of 295 Old 07-03-2012, 10:30 AM
Mol
Mol's Avatar
Okay, I'm more likely to fold to someone who knows their biz...so I'll woefully accept your explanation.
However - I do own a '12 Sahara with 3.73 and auto, and I'm not beside myself with the improvement. Plus, I really like that deep granny first gear in the rocks
Edit - looks awesome...perhaps I overlooked this, but what tires do you have on there now? Temp loaners from another rig?
Mol is offline
post #103 of 295 Old 07-03-2012, 11:26 AM
Imped
Imped's Avatar
Needs fotees.
OlllllllO
IndyORV
Imped is online now
post #104 of 295 Old 07-03-2012, 03:00 PM
MountainMan864
Maybe if you had a real transmission haha youd want the 5.13s. Great looking jeep. Cant wait to see the results when you get the bumpers and everything else on.
post #105 of 295 Old 07-03-2012, 03:46 PM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Alright, I believe you as well. I had the 4.10s and they were fine with the 35's. So, today I was driving out to the shop at 80mph and doing around 3200 rpm. I don't want to going any higher than that!
I'm looking forward to putting on the 37s and seeing where I am. Currently 35s.
Like us on Facebook
Savvy is offline
Savvy LJ Test Mule Savvy TJ Wrangler Technical Forum 1328 08-09-2015 07:40 AM
Putting Savvy Armor to the Test steve578 TJ Wrangler Technical Forum 63 10-25-2011 10:07 AM
Anyone have Savvy corners and non-Savvy sliders? Fropleyqk Wrangler General Discussion 2 10-15-2011 09:02 AM
Bucking like a pissed off mule....... jeepgunner12 TJ Wrangler Technical Forum 18 09-05-2010 11:09 AM
YJ buckin like a Mule & my saddle dont fit...HELP! Coolhand1 YJ Wrangler Technical Forum 10 05-05-2007 02:52 PM
