Sat Radio - JeepForum.com
post #1 of 10 Old 09-19-2006, 06:53 AM Thread Starter
tbrkek
Sat Radio
Anyone with the Sirius radio having any problems of it always going out. I am assuming it is because the attennae is not on the roof, obviously. With that...anyone know where the antennae for the satellite radio is? I have XM in another vehcile through GM and I hardly every lose the station. In the Jeep, I can't go more than 5 minutes without it cutting out. It only cuts out for a few seconds, but still annoying! Anyway, not sure why they have it in a vehcile where it can't be mounted on the roof, thus giving out poor coverage.
tbrkek is offline
post #2 of 10 Old 09-19-2006, 07:59 AM
jeepboy85
I don't know if you have the JK or a TJ, but I have Sirius in my TJ and it works perfectly fine. I have a plug and play radio with the antenna on the drivers side roll bar and I never loose reception, works perfectly fine through either the cloth of the soft top or the fiberglass of the hardtop.
jeepboy85 is offline
post #3 of 10 Old 09-19-2006, 09:03 AM
Rocky529
Rocky529's Avatar
I'm not sure where the factory mounts the antenna in the JK... but seeing as it is either fiberglass or canvas above it, I don't see why it is cutting out.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #4 of 10 Old 09-19-2006, 09:41 AM
nierace
nierace's Avatar
2003 WJ
It depends on where you're driving...mine cuts out when I am driving on back roads with tons of tree coverage...on open road it never cuts out. In the winter it hardly cuts out and in the summer it does get pretty annoying.
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #5 of 10 Old 09-19-2006, 07:52 PM
stl_07
same here! i have had sirius for 3 years now and the only time it cuts out is when i go under bridges and at the gas station. i also noticed it when i am between large buldings (downtown highrise) it cuts out from time to time. just needs that direct line to the sky..
stl_07 is offline
post #6 of 10 Old 09-19-2006, 08:20 PM
MuddyJeepZJ
MuddyJeepZJ's Avatar
Another reason why sirius sucks and XM is better. Sirius spends all thier money on names while XM puts money into technology.
2004 Jeep Wrangler Rubicon
2003 Dodge Ram 3500
MuddyJeepZJ is offline
post #7 of 10 Old 09-19-2006, 09:22 PM Thread Starter
tbrkek
Even still...anyone know where the antennae is for the factory installed Sirius. My JK came with it for a year...but where the heck is the antennae??? It can't be combined with the FM/AM antennae, can it??
tbrkek is offline
post #8 of 10 Old 09-19-2006, 10:23 PM
parkstephen
Mine is stuck on the inside of the front windshield by the driver's front right lower corner. I got a year's service with my purchase of my 06 too.
Anybody else's there?
parkstephen is offline
post #9 of 10 Old 09-22-2006, 09:03 PM
yellj
Can you explain that, I would have thought it is those making the Head Units and antennas, do they use different satellite bands (not sure if that is the right term)
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
yellj is offline
post #10 of 10 Old 09-23-2006, 09:43 AM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
I just don't like all those commercials on talk show/new channels. I end up listening to BBC news since they have no commercials, of course, Howard Stern. My antenna is inside the rollbar cover, sitting on top of the rollbar. Do loose signal sometimes but mostly it's fine even going under tunnels and trees. I think there are times it cuts out more than other times going thru something with short loss of line of sight to the sky... I attribute this to satellite position at the time. I'm curteous of the signal quality of the in-line Sirius unit because my Sportster quality isn't good even though I'm using RCA connection to back of OEM unit.
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
Installing radio, now no interior lights/no radio working? What fuse? Ford4Now TJ Wrangler Technical Forum 7 03-31-2012 07:49 PM
new radio install - distributor noise on Radio bestos YJ Wrangler Technical Forum 8 10-03-2009 08:47 PM
Guages and Radio doesn't work after radio install HoosierDaddyTJ TJ Wrangler Technical Forum 3 04-15-2009 01:57 AM
Radio Fuse /radio not working of after fog light install? Bonesboy JK Wrangler Technical Forum 0 03-17-2009 03:38 PM
Is Radio wiring present if jeep originally came without a radio gary1 YJ Wrangler Technical Forum 14 02-07-2006 09:10 PM
