Sahara - Axle locker? Axle ratio? - JeepForum.com
post #1 of 9 Old 02-23-2007, 03:43 PM Thread Starter
Meir10
In the Sahara 2007 specs there is "Locker rear axle". Does anybody know if it Is a Real Differetial locking and if so - ARB \ Detroit \ other? is it standard?
Could you guys recommend on a locker for JK 2007 - Dana44?
An axle ratio of 4.1 is option - should I gp for it?
Meir
Meir10 is offline
post #2 of 9 Old 02-23-2007, 03:55 PM
JK_Jeep
JK_Jeep's Avatar
Meir
locker and 4:1 transfer case is only available in the Rubicon I believe
IT'S A JEEP THING!
Originally Posted by sierraexplorer
Thanks, if it is that good than I'm sure that they can't sell it in California. Everything else is illegal in this state except the illegalsl
JK_Jeep is offline
post #3 of 9 Old 02-23-2007, 03:59 PM
Kyoseki
Inconceivable!
Kyoseki's Avatar
4:1 Transfer case is Rubi only, but you can get 4.10 axle ratios as an option on the X or Sahara (they're a standard part of the tow package anyway along with a couple of others I believe).
Due to lack of interest, tomorrow has been canceled
Kyoseki is offline
post #4 of 9 Old 02-23-2007, 04:38 PM
CJATE
I have not ordered yet, so I may be wrong, but the book indicates you can get a rear locker in the Sahara. Does not look like it comes with the 4:1 t-case but a locker in a 44 in the rear, seems to be available
front locker is not available in the Sahara
I think I would be irritated form time to time with a rear but no front locker.
CJATE is offline
post #5 of 9 Old 02-23-2007, 10:51 PM
newvances
Standard is 3.21 Axle Ration with Dana 44 Rear End
newvances is offline
post #6 of 9 Old 02-25-2007, 09:22 AM
redpony03
read the fine print in the bouchure it says late availability, seeing they are 8mts into the productin run, late is an understatment. as for the rest of the replys it is going to be the same locking axle found on the rubbi!! not sure about it only being available only in the 4:10 ratio, but it will be electric orperated, not a bad deal if it ever gets here!!!!seems jeep is playing delay games to keep the interest up, just like with the tj launch had to wait over 1yr to get the 44 axle on the sport model. but now it's gig radio, locking axle, hard tops. what gives? how can you go into production w/no part suppliers on board?????
redpony03 is offline
post #7 of 9 Old 02-25-2007, 12:33 PM
SecondTJ
SecondTJ's Avatar
On Unlimiteds and 2drs with the 6-speed
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #8 of 9 Old 02-25-2007, 12:40 PM
Prot
Prot's Avatar
2014 JK Wrangler
Go for the trailer towing package. It includes 4.10 gearing, although you can get the 4.10 gearing without getting the trailer towing package. The Track Lock is available with either gear ratio. The axle locker is not the same thing as the Trak Lock. Track Lock is another name for limited slip differential. Axle Locker is something that allows you to engage positive traction. You can get axle locker with or without Track Lock and vice versa. 4.10 gearing can come with either one or both Track Lock and axle locker. I'm not sure about the 3.21 gearing. If you are going to go with bigger tires and/or tow something, you'll want the 4.10 gearing and depending on how big of tires you go with, maybe even something more geared down than that from the aftermarket.
Prot is offline
post #9 of 9 Old 02-25-2007, 03:15 PM
SecondTJ
SecondTJ's Avatar
You can't get the limited-slip diff with the locker. If you get the locker, it will have an open diff, without the option of lsd
I don't think the locker is a big name company like ARB. Jeep used Tochigi Fuji Industrial Co., Ltd (later became GKN driveline) for their lockers in the TJ, not sure if they still use the same company for the JK
SecondTJ is offline
another 08 axle ratio ???? nycaubrun JK Wrangler Technical Forum 9 08-20-2007 11:47 AM
Axle Locker for 3:07 Ratio Rear End pgt2 TJ Wrangler Technical Forum 2 07-12-2007 06:26 PM
Axle ratio ? Mike5150 TJ Wrangler Technical Forum 4 02-11-2006 11:01 PM
Sahara axle ratio yamar18 TJ Wrangler Technical Forum 4 02-10-2005 09:33 AM
Axle ratio on 1994 sahara 5spd 4.0 Tony1 YJ Wrangler Technical Forum 3 06-28-2003 08:11 AM
