Rustproofing - JeepForum.com
post #1 of 27 Old 11-02-2013, 09:35 AM Thread Starter
vacman11
Rustproofing
Sorry new to site is there a thread on rustproofing Wrangler , being in the rust belt here in Cleveland, thanks
vacman11 is offline
post #2 of 27 Old 11-02-2013, 12:16 PM
1222
RIP John
1222's Avatar
I don’t recall seeing one and I doubt you really need to do anything more to protect it. I imagine that most modern vehicles manufacturers go out of their way to add plenty of protection in that department. Perhaps just clean your Jeep every now and then and forget about it.
Since I don’t live in the “rust belt” I could be wrong but other than going to extreme’s I really wouldn’t worry myself over it.
1222 is offline
post #3 of 27 Old 11-02-2013, 01:28 PM
1995_XJ
1995 XJ Cherokee
Rust sucks, I only own a xj and it's my worst enemy.
I might be stepping up to a jk here soon, and I plan on doing some kind of rust proofing.
However after you drive on a lot of salt it's good to spray it off, helps a lot
1995 Cherokee Sport
1995_XJ is offline
post #4 of 27 Old 11-02-2013, 02:20 PM
SubAtomicGenius
2011 JK Wrangler
Yeah, go to NAPA, buy an air gun (you need a compressor), some "red" rust check, and a 5-gallon bucket of their Napa-brand rustproofing (the snotty stuff). Total cost just over $100 (Canada).
Go home, spray the "red" stuff around your body, doors, and into all of the fine gaps. Then use the air gun to whollop the bottom tub, inside the chassis, mounting points on the axles, inside bumpers, inside body panels, etc. The only limits being: a) how messy you want it (or don't mind it) and b) try to stay away from the exhaust - it smells like burning crayons when your driving and kinda makes you nervous (haha). You should have enough left over to do three cars - or the same JK for the next three years.
It is very messy! But it is cheap and it works. If you're meticulous, it will be a better job than the rust-prevention shops.
SubAtomicGenius is offline
post #5 of 27 Old 11-02-2013, 02:26 PM
1222
RIP John
1222's Avatar
So has anyone just left the JK’s alone as far as adding extra rust proofing and for the most part been problem free?
1222 is offline
post #6 of 27 Old 11-02-2013, 03:36 PM
SamM
SamM is offline
post #7 of 27 Old 11-02-2013, 07:39 PM
Tragyn
2011 JK Wrangler
I have some electric gadget the dealer put on for me. I've heard good things. I'm in Canada so it's a fair concern.
Tragyn is offline
post #8 of 27 Old 11-03-2013, 01:38 PM
SubAtomicGenius
2011 JK Wrangler
Lol, cathodic/galvanic protection (what the device is supposed to emulate) only works on ships and boats, unless you're planning on parking your Jeep in the ocean.
post #9 of 27 Old 11-03-2013, 02:05 PM
krawler510
I bought a'99 XJ with 180,000 milesthat had full underbody coating and rust is minimal to non existent on this thing. It's amazing.
Bolts are pretty bad but the unibody is rock solid.
When I had a wrangler I cleaned the frame and axles and painted them every spring.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #10 of 27 Old 11-03-2013, 05:15 PM
FleshEater
2014 JK Wrangler
A buddy of mine has a 2010. There are no spots forming on the body or frame, but everything else is well coated in surface rust. Without doing something, your Jeep will disintegrate from under you in the rust belt.
I just got my 2014 and noticed that Chrysler left plenty of places for moisture and salt to lay untouched. Most likely I'll have it undercoated professionally before the salt flies.
2014 JKU Rubicon *DAILY DRIVER*
Gone but not forgotten; 2005 LJ *SOLD* 1987 XJ *SOLD* 2002 WJ *SOLD* 1995 ZJ *SOLD*
FleshEater is offline
post #11 of 27 Old 11-03-2013, 06:03 PM
muddr1
Best thing to do, and I have done this for years with great results,
After a storm, and all the salt goes down. Once the road is dry, usually a day or two later. Hit the pressure washer at the local car wash. I usually get down, do underneath, and everywhere I possibly can get. If you keep the jeep clean. It helps alot. And once spring arrives I pull all the inner fenders and drag me pressure washer out and pressure wash the heck out of it.
If we knew what we were doing it woulnt be called research
Albert Einstein
There are no rules here, were trying to accomplish something.
Thomas Edison Keep Calm,Chive On
muddr1 is offline
post #12 of 27 Old 11-03-2013, 07:55 PM
mello
Give it the POR 15 treatment, the best rust prevention technique out there hands down. It can even be applied directly over rust and it will stop it in its tracks and prevent new build up.
mello is offline
post #13 of 27 Old 11-03-2013, 08:01 PM
awinski
Por 15
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #14 of 27 Old 11-03-2013, 08:19 PM
tjkj2002
2002 KJ Liberty
The best way to keep rust at bay,wash and wash often and pay more attention to the undercarriage then the shiny painted parts.
tjkj2002 is offline
post #15 of 27 Old 11-03-2013, 08:44 PM
95YJMountie
95YJMountie's Avatar
My grandfather showed me how to prevent rust recently, not sure how successful it will be, but its worth a shot. He said he used to take empty plastic spray bottles, and would take a couple quarts of oil, put them in the spray bottle, crawl under the vehicle, and spray away.
My build:
95YJMountie is offline
