Running power threw firewall - JeepForum.com
post #1 of 13 Old 08-28-2010, 05:22 PM Thread Starter
xcapt
Can anyone give me a hint on an easy spot to run power into the cab from the Battery, I'd rather ask then drill into something. Thank you for the help
xcapt is offline
post #2 of 13 Old 08-28-2010, 05:36 PM
qf4phlyer
qf4phlyer's Avatar
There is a side plastic cover on either side of the dash, remove the cover, you will see a round hole with expandable foam, use a piece of wire hanger to punch through the hole into the engine compartment.
08 Wrangler X DETN8R Yellow Rough Country 2.5" progressive rate coil lift, 2.2 shocks. 1.25" body lift, disco's, steering stabilizer. Benchmark EVAP skid. TeraFlex front bumper with shackles. 35x12.5x15 BFG A/T KO's on MB72 wheels.Cobra 75 on a Firestik. Arizona Rocky Road antenna mount. Ward bug shield, DayStar hood wranglers, upper dash panel. Qtech arm rest.
2002 Wrangler Sahara RIP
1979 CJ 7 258 RIP
1975 Cherokee S 401 RIP
qf4phlyer is offline
post #3 of 13 Old 08-28-2010, 06:59 PM
240Dbio
2010 JK Wrangler
I ran it under the jeep through one of the drain plugs (rubber gaskets) Thats if your running it to a amp or something. Rubber gaskets all around the jeep :P (drain plugs)
240Dbio is offline
post #4 of 13 Old 08-28-2010, 11:46 PM
Douglas S.
I recently discovered a weatherpack bulkhead connector. Pricey, but worth it IMO.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #5 of 13 Old 08-29-2010, 12:55 AM
Warlord2
There is a like 1 1/2" rubber grommet that is behind the steering wheel that I have ran all 10 of my wires through.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #6 of 13 Old 08-29-2010, 07:33 AM
Blu-Jacket
2009 JK Wrangler
Where did you find it? How much is pricey?
Blu-Jacket is offline
post #7 of 13 Old 08-29-2010, 07:50 AM
thedirtman
thedirtman's Avatar
I found a rubber boot under the battery with a wiring harness running thru it, made a small slit in the outer rim of it and fished the wire with a bent close hanger.
thedirtman is offline
post #8 of 13 Old 08-29-2010, 07:52 AM
wilywillie
I hope it's strong, too....to keep the power from throwing the firewall. That ain't no joke!
wilywillie is offline
post #9 of 13 Old 08-29-2010, 08:32 AM
SilverSwamper
2011 JK Wrangler
behind battery
If you pull the grey installation back that is on the firewall just behind the battery there is a hole there. There will be a shiny black material like tape under it that you can push through with your finger and run the wire right in. It will come out a little high on the inside of the firewall but runs right down. This is very easy to get too. It is just under the wiring harness on the firewall behind the battery. Hope that helps you out. I don't have enough posts to put up a pic for you.
SilverSwamper is offline
post #10 of 13 Old 08-29-2010, 04:23 PM
Douglas S.
Ebay for about $40 CAD
post #11 of 13 Old 08-29-2010, 04:41 PM
JIMBOX
There's also 2 seperate 2" access holes' on the drivers side in 07/08/09/10 JKU's-
Just above the brake vacuum assist diaphram and 1' below the steering column and a couple inch's outboard-
Both have rubber plugs inem-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #12 of 13 Old 08-30-2010, 01:15 PM
GPV
Whatever you do install a fuse as close to the battery connection as possible. These are easily found anywhere where they sell car stereos and such.
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #13 of 13 Old 08-30-2010, 07:53 PM
badgerking
Ditto!
badgerking is offline
firewall access , power
Running wires through firewall miked2905 JK Wrangler Technical Forum 7 03-24-2010 04:17 PM
JK Firewall Hole on Passenger side for power inverter? 76406 JK Wrangler Technical Forum 2 12-17-2009 01:45 PM
Help running wires through the firewall KICKER32 JK Wrangler Technical Forum 15 03-16-2009 09:28 PM
Running wires through firewall MZH29 TJ Wrangler Technical Forum 17 01-29-2007 12:13 PM
Running wire through firewall crgrissom TJ Wrangler Technical Forum 2 01-06-2006 08:12 AM
