Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares - Page 2 - JeepForum.com
post #16 of 45 Old 03-10-2011, 12:18 AM
Hussler
1992 XJ Cherokee
Originally Posted by MoparToYou View Post
I love that look, makes it look stock. Why even bother making lifts 4.5 or higher for the JK
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #17 of 45 Old 03-10-2011, 06:35 AM
calys003
Not to hi-jack this thread, but to add to it ... here is a picture of my friends Jeep with a 3" Polyperformance long arm lift, and 37s, with the stock flares. With the axles centered in the wheel opening the 37" tire clears the pinch seam by 1/4" in front and in the rear. Minimal trimming of the inner plastic liner at the back of the rear fenders is needed, and the rock rail needs to have 1 1/2" cut off its back end. He is running the bump stop extensions that come with the suspension lift.
To center the axles did he have to get new drive shafts or was there enough play in the stock ones?
calys003 is offline
post #18 of 45 Old 03-10-2011, 06:47 AM
MoparToYou
2014 JK Wrangler
There is enough play in the stock driveshafts.
2014 Grand Cherokee Laredo: 2" Eibach lift, 265/70R-17 BFG KO2's, 17x9 KMC Addicts
MoparToYou is offline
post #19 of 45 Old 06-20-2012, 09:28 PM
SouthernJK
2009 JK Wrangler
I am having rubbing issues with my 295/70R18 tires on stock rims. Tires measure around 34.5 so there shouldn't be any rubbing. I get rub on the front lower control arm when turned all the way right or left. Could this be fixed with wheel spacers?
SouthernJK is offline
post #20 of 45 Old 06-20-2012, 09:50 PM Thread Starter
planman
Thanks to all Mod erators
planman's Avatar
Yes. You absolutely must run wheel spacers to run wider than stock tires on stock wheels with no rubbing.
You want Spidertrax spacers. You will have to remove all the stock lug retainer clips to run them without wobbles.
planman is offline
post #21 of 45 Old 06-20-2012, 10:04 PM
SouthernJK
2009 JK Wrangler
Thanks! Hope this works out i am ready to start hitting the trails and have some fun!
post #22 of 45 Old 06-21-2012, 10:30 PM
ZIMM18
ok so here goes and bear with me! Im going 37's for my stock Rubi 6spd. My plan after reading this thread is......
1. 2.5 TF BB
2. 1 or 1.25 BL
3. Spidertrax 1.25 wheel spacers
4. Stubby front bumper end caps
5. Trim and sawzall all pinch weld seams including stock Rubi rock rails (2")
6. Trim and cut all stock flares to make them flatties until my GenRight budget shows up
Do JKU stock Rubi springs raise the lift height more than the stock 2dr Rubi springs?
I'm thinking pick up stock JKU Rubi springs if thats the case, seems like those are easy pickings in the classifieds...
Thanks for your input on this......I'm driving to the other side of the island tom am to pick up my new jeep and I cant wait!! Mahalo!!
Not Banned
ZIMM18 is offline
post #23 of 45 Old 06-22-2012, 09:15 AM Thread Starter
planman
planman's Avatar
1. 2.5 TF BB
2. 1 or 1.25 BL
The JKU Rubi springs are just stiffer. Because of this, the give a little lift.
I wouldn't do them except for the fronts only, and only after you add something heavy to the front like a steel bumper and winch.
I don't like a stiff ride.
Also, I'd do the BB with shocks instead of the shock extensions because the extensions won't give the same extension/articulation as newer, longer shocks.
planman is offline
post #24 of 45 Old 06-22-2012, 10:38 AM
ZIMM18
ahh cool, thanks for the heads up! I'd just hate to toss my factory rubi shocks with such low miles...they are bilstein right?
Not Banned
ZIMM18 is offline
post #25 of 45 Old 06-22-2012, 12:10 PM
ncb
Definitely not Bilstein.
ncb is offline
post #26 of 45 Old 06-22-2012, 01:14 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
I don't condone spending the absolute least amount of money possible to push the biggest tires possible...you'll just end up spending twice. Buy a decent set of coils, at the very least.
Mol is offline
post #27 of 45 Old 06-22-2012, 01:17 PM
smcutter
And don't forget to weld your front axle into a girdle and add a corset to the C's and put some sleeves on your shirt. Or something like that.
For the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline
post #28 of 45 Old 01-09-2013, 08:11 PM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
Are you cutting 2" off the rails on just one end or 1" off each end?
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
post #29 of 45 Old 01-09-2013, 09:25 PM Thread Starter
planman
planman's Avatar
2" off the back ends.
planman is offline
post #30 of 45 Old 09-29-2013, 04:30 AM
Austinchaynes
2009 JK Wrangler
Another JK with a 2.5" lift, flat fenders and 37s (no body lift).
I know I'm about 2 years late to this thread but what kind of tires are these?
Austinchaynes is offline
Would 35" Tires & Bushwacker Flat Flares rub w/o a lift? JKashat JK Wrangler Technical Forum 45 05-01-2014 12:12 PM
Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift jondotcom TJ Wrangler Technical Forum 10 03-06-2010 02:43 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
What shocks should I run? 4" springs, 1" boomerang shackles, 1" body lift Dwayne93YJ YJ Wrangler Technical Forum 3 06-02-2008 11:15 PM
