Rugged Ridge XHD Non Winch Bumper Stronger than Bumper w/ Winch Plate??? - JeepForum.com
post #1 of 8 Old 04-20-2009, 01:04 PM Thread Starter
mlupacchino
After seeing this picture of the Rugged ridge XHD front bumper w/ winch plate, I saw just how much material is cut out from the stock stubby.
Compare that to the non winch plate version,
It seems to me that the winch plate version wouldn't stand up to a direct impact as well as the non winch mount version due to the larger cut out portion meant for the winch. What do you guys think? Am I correct in this assertion, or would the winch plate bumper without the winch hold up about as well to a direct impact to the front of the bumper?
mlupacchino is offline
post #2 of 8 Old 04-20-2009, 05:55 PM
Rudinater
2009 JK Wrangler
No links , , ,
Thanks
Rudy Ackerman
In Oregon for now
Red 09 Unlimited Rubicon - Teraflex 4inch long arm lift, Elka shocks, 5:38 gears, 37inch GY MTR's, Expedition Core front bumper with Warn PowerPlant HD, RS-E rear bumper and carrier, RS-E step rock sliders.
Rudinater is offline
post #3 of 8 Old 04-20-2009, 06:21 PM
SETXWarrior
I have the winch mount version. In a direct impact, the first thing to make contact would most likely be the recovery points, which are connected directly to the frame. I don't think one would be any better/worse than the other.
Conversely, with the winch mount version you also have the frame of the winch to add rigidity to the center of the bumper.
SETXWarrior is offline
post #4 of 8 Old 04-21-2009, 06:35 AM Thread Starter
mlupacchino
If you did not have a winch, which bumper do you think would be stronger?
post #5 of 8 Old 04-21-2009, 08:17 AM
N2rock
N2rock's Avatar
IMHO- it is a moot point.
First and foremost- either one is much stronger than the stock bumper.
secondly- if someone is purchasing the winch version, that means they intend to add a winch. Once you add a winch and winchplate in there, the strength is as good (if not better) than the non winch version
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #6 of 8 Old 04-21-2009, 09:55 AM
BigJerm
I dont think I would want either bumper to withstand an impact... I mean force has to go somewhere. If it doesnt bend the bumper... what part of the Jeep would you like for it to bend? For what its worth, when I had the winch version I hit it on rocks, trees, dirt mounds and it never bent.
07 Jeep Wrangler Unlimited Rubicon
BigJerm is offline
post #7 of 8 Old 04-21-2009, 09:59 AM
SETXWarrior
Like I said, "I don't think one would be any better/worse than the other."
post #8 of 8 Old 04-21-2009, 06:01 PM
Tornado
Do you need to add a winch plate? Doesn't the winch mount right into the winch mount version?
Tornado is offline
Can't Mount a Winch on Rugged Ridge Tube Bumper! williamellison TJ Wrangler Technical Forum 33 05-21-2014 10:19 PM
Rugged Ridge XHD winch bumper Stinger Lights? owtdorz JK Wrangler Technical Forum 2 01-15-2011 08:02 AM
Rugged Ridge Mod Bumper and winch install question? 1398653 JK Wrangler Technical Forum 6 01-25-2010 06:51 AM
Rugged Ridge Bumper - No Winch ten27oh4 JK Wrangler Technical Forum 14 03-24-2009 12:29 PM
winch for Rugged Ridge bumper, what fits? sheriff1 JK Wrangler Technical Forum 11 11-11-2008 09:11 PM
