Rubicon Take -Offs vs Teraflex Leveling Kit - JeepForum.com
post #1 of 53 Old 05-17-2010, 09:51 PM Thread Starter
plac
2007 Sahara 2DR
I am going to be comparing the two options in the next couple weeks. I have already had a Teraflex 1" lift kit but gave up on it too quick. Now, I have some 2010 Rubicon/Unlimited/Hardtop spring/shock take-offs coming soon.
Rubicon springs
Still oem setup for dealer
Stiffer ride than my Sahara
Less body roll
Possible 1"-1.5" lift (Turned out to be 3/4" front, 1" rear)
Retain softer Sahara ride
Guaranted 1" lift
Dealer won't like the aftermarket parts for any issues
This will all boil down to which ride I like better. Rather, if I can put up with the increased stiffness from the Rubicon springs and shocks. I like the softnes of the Sahara a lot, but it does have a lot of body roll on turns. If I can't take the Rubicon ride, I will have to buy a Teraflex kit again, so i can keep my Sahara springs. Not changing my stock 32" tires for quite a while, they have 75% left.
NEW VIDEO MADE 12/17/2016 ** 3" lift from oem Rubicon springs!*
2015 Subaru WRX
plac is offline
post #2 of 53 Old 05-18-2010, 05:47 AM
daggo66
2009 JK Wrangler
Before you install the springs take a look at the number on the tags. Rubicon springs are not necessarily stiffer than the springs on any other Jeep. The last 2 digits need to be higher than the last 2 digits on your springs. The stiffest (highest number) springs tend to be on Unlimiteds with the tow package.
Tom
daggo66 is offline
post #3 of 53 Old 05-18-2010, 07:47 AM Thread Starter
plac
ya, i should have added all that info in here too..
mine: 14/15 and 55
the new ones off Rubicon Unlimited with hardtop and tow package
18/18 and 58
2015 Subaru WRX
plac is offline
post #4 of 53 Old 05-18-2010, 10:26 PM
Scooter_Trash
So what is the difference between the rubi shocks and the sahara shocks? Reason I ask is I have the TF leveling kit and was thinking of putting on some Rubi takeoffs.
Mine are 15 and 58 on a Sahara with the tow package. I'm thinking maybe I'll want to add some Rubi front springs then.
Scooter_Trash is offline
post #5 of 53 Old 05-19-2010, 05:38 AM
RAZORBILL
RAZORBILL's Avatar
2014 JK Wrangler
Since you have an 07 you may benefit from 2010 springs in the rear also. I'm sure the stock springs have sagged a little. You should be able to find the 17/18's front & 58 or 59's rear pretty easily.
Previously owned: 80 CJ-5, 97 TJ,99 XJ, 95 YJ,10 JK Rubicon Unlimited, 10 JK Sport
RAZORBILL is offline
post #6 of 53 Old 05-19-2010, 07:44 AM Thread Starter
plac
most people say Rubis are stiffer, but i also seen some threads where people say sahara and rubicon shocks are the same with different paint.
2015 Subaru WRX
plac is offline
post #7 of 53 Old 05-19-2010, 01:39 PM Thread Starter
plac
i will probably get the springs today, i might test fit the fronts tonight. ill measure before and after of course.
2015 Subaru WRX
plac is offline
post #8 of 53 Old 05-19-2010, 06:05 PM Thread Starter
plac
RESULTS
Job duration: 1 hour 45 mins, replaced all springs and shocks and steering stabilizer.
4 shocks + 1 steering stabilizer + 4 springs. Arrived cherry as you can see. This Rubicon was driven from the dealer to the shop directly, and these are 82 mile take-offs:
2 Rubicon front springs, both 18's:
2 Rubicon rear springs, both 58's:
Comparing the front spring. Barely any taller, maybe a 1/2 coil. Looks like the same thickness to me:
Front spring installed, cakewalk. When you disconnect everything properly, the springs just fall out:
Front shock part numbers. Sahara: 52126711AD/Rubicon: 52126712AD
Same length, nothing really difference in appearance:
Another pic comparing the front springs:
CHECK OUT the difference in steering stabilizers:
The Rubicon stabilizer HAS to go in this direction. In the next pic you will see why. Notice one side of the shock body is a lot bigger:
The thin side has just enough clearance here. The thick body side would have rubbed on that bracket:
Rear shock comparo. Sahara: 52126751AC/Rubicon: 52126752AC
Comparing rear springs, again, maybe a 1/2 coil difference in height, not much:
HEIGHT RESULTS!! 3/4" lift in front, 1" lift in rear.
The lift height is just what I wanted, so I hope I like the ride. If I dont, I will take all this off, go back to my Sahara springs/shocks, and get a Teraflex leveling kit for a guaranteed 1" lift.
2015 Subaru WRX
plac is offline
post #9 of 53 Old 05-19-2010, 06:33 PM
Ron Burgundy
Team CANON
Ron Burgundy's Avatar
2009 JK Wrangler
nice share~~!
I appreciate all of the info & good people on this site.
JK Sahara 2dr
Ron Burgundy is offline
post #10 of 53 Old 05-19-2010, 06:36 PM Thread Starter
plac
I am pleasantly surprised with the first drive. Its not too rough at all. Lot better than I was expecting. I'll test a couple more days but I do think i'll be keeping these in. Can't really tell the difference in a 3/4" lift when driving of course, so thats not too exciting. I may look into the Terflex leveling next if I want just a tad more. I could go a tiny bit higher while keeping these tires.
2015 Subaru WRX
plac is offline
post #11 of 53 Old 05-19-2010, 06:48 PM
Ron Burgundy
Team CANON
2009 JK Wrangler
did the height difference settle at all after you drove it?
JK Sahara 2dr
post #12 of 53 Old 05-19-2010, 06:50 PM Thread Starter
plac
no. i had already jounced it real well before measurements. the height makes sense, these were off a much heavier unlimited model.
2015 Subaru WRX
plac is offline
post #13 of 53 Old 05-19-2010, 06:53 PM
Ron Burgundy
Team CANON
2009 JK Wrangler
makes sense, just checking, thx.
JK Sahara 2dr
post #14 of 53 Old 05-20-2010, 09:18 AM
Scooter_Trash
If you decide you don't want to keep the shocks/springs/stabilizer, PM me. I'll take them off your hands.
post #15 of 53 Old 05-20-2010, 09:43 AM Thread Starter
plac
HA. I think I'll be keeping them. No issue with harshness. And no drawbacks from gaining 3/4-1" height. Less wallow in turns and off curbs on an angle.
2015 Subaru WRX
plac is offline
Teraflex leveling kit and 34" tires? ncb JK Wrangler Technical Forum 40 04-07-2012 02:41 PM
Teraflex leveling kit or RC 2.5" jhc09 JK Wrangler Technical Forum 27 04-27-2010 05:34 PM
Teraflex Jk Wrangler Leveling kit JKommuter JK Wrangler Technical Forum 14 06-02-2009 04:39 PM
Price for Rubicon take offs ( buy sell rubi wheels ) Mudhound0530 JK Wrangler Technical Forum 5 05-07-2009 10:37 AM
Will tj rubicon take offs..... JkRyder JK Wrangler Technical Forum 9 04-22-2009 06:09 PM
