rubicon springs/jku - JeepForum.com
post #1 of 6 Old 08-19-2013, 04:20 PM Thread Starter
dukeboy_318
rubicon springs/jku
I have a JKU X. Ive found a set of rubicon springs for cheap. I know the fronts will be an improvement but will the rear springs do me any good since I have the towing package?
Numbers on these rubicon springs are:
5212/6314AC
6800/4256AA
dukeboy_318 is offline
post #2 of 6 Old 08-19-2013, 11:09 PM
suicideking
5212/6314AC
6800/4256AA
The numbers that matter are the last numbers. Are the numbers you posted the springs you're buying? Or the ones you have now?
What you have is a 14/56 combo whereas the max strength springs are 19/60. 14/56 is not likely to be worth the swap. Yours might already be stronger.
On my 2012 with Max tow I had 15/59. So the rear were close to the max strength, front not so much.
Do a google search for jeep jk springs. There's lots of posts on different forums that explain the spring rates in great detail.
suicideking is offline
post #3 of 6 Old 08-20-2013, 06:31 AM Thread Starter
dukeboy_318
The numbers posted are those of the Rubicon springs I'm looking at. I've not climbed under mine yet to see what the numbers are.
post #4 of 6 Old 08-20-2013, 06:50 AM
4wdjeepguy
I don't think it would be worth it unless they're free.
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
4wdjeepguy is offline
post #5 of 6 Old 08-20-2013, 09:07 AM
suicideking
Not worth it. Look at yours, probably the same or similar.
Look for some 19/60 or close.
post #6 of 6 Old 08-21-2013, 08:45 AM
JoonHoss
2011 JK Wrangler
There are no 'Rubicon' springs, all springs that come on JK's are the same, save for the spring rate as noted by the last two numbers as stated above.
It does not matter what model JK the springs come off of. The only thing that matters is the last two numbers on the tag. The springs for an S, sahara, rubicon all come from the same bin depending on their options (like tow package, hardtop,etc.)
HTH
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
