Rubicon lockers - Page 2 - JeepForum.com
post #16 of 20 Old 06-17-2010, 06:05 PM
ribs
Originally Posted by mrsig View Post
1)correct not disconnected
2)Lights stay on solid when engaged.
Thanks. I have only used my lockers once and that was when I was already stuck in a mud hole. I guess that is why It didn't seem like they made any difference when I turned them on as the lights were only flashing.
Originally Posted by redrockin7 View Post
...As for the lockers engaging, sometimes it will take a few feet before they lock in, or even unlock after turning them off....
Is it possible to lock them when I am at a stop?
I feel like I should know this stuff, I even read the owners manual front to back.
Originally Posted by notoriousdoa View Post
we had a peep hole looking into the girls jeep forum, but someone used it as a glory hole so they patched it up.
Originally Posted by LarryGrant View Post
...And no the truck dont give BJs but guess you are not married as wifes dont give them either. :rolleyes:
ribs is offline
post #17 of 20 Old 06-17-2010, 06:12 PM
redrockin7
Technically, yes, they should lock as soon as you hit the switch. All that's happening is a 12v signal is being sent to the electronic locker and causing it to lock/engage. I honestly don't know why it sometimes takes a few feet to really engage, but it just does. LOL.
Most of the time mine lock and unlock just fine, as soon as I touch my switches, though. Usually at a dead stop...
There is a vid on youtube that one of the custom shops posted I believe showing an e-locker out of the housing engaging and disengaging and how it really works.
redrockin7 is offline
post #18 of 20 Old 06-17-2010, 06:15 PM
skivviss
2010 JK Wrangler
i swear i've been able to get mine to engage when i've been in a swivel position (driver front and passenger rear both with no traction). seemed to just take a few seconds of letting the gears spin and the tractionless wheel on the axle spinning. release the throttle and wait a moment and then the lockers stopped flashing and i was moving upward again.
i don't think it was the BLD system, sometimes if its just one wheel and a small slippery patch i don't even bother with the lockers. definitely not as controlled feeling as the lockers when doing that.
skivviss is offline
post #19 of 20 Old 06-17-2010, 07:45 PM
ribs
So I just tested my lockers out here to see if they work. The front locker light will go solid but the rear one wont, it just flashes. Any suggestions? It should still be under warranty.
ribs is offline
post #20 of 20 Old 06-17-2010, 11:01 PM
Avernar
2010 JK Wrangler
Try turning the steering wheel to the side a little bit to make the back wheels turn at a slightly different rates to let the dog teeth mesh.
Avernar is offline
Rubicon Air Lockers vs ARB Lockers MLA 97TJ TJ Wrangler Technical Forum 17 07-09-2012 04:37 PM
Lockers on a Rubicon 08killerb JK Wrangler Technical Forum 15 09-30-2009 10:34 AM
rubicon lockers? hoot20 TJ Wrangler Technical Forum 62 12-08-2008 08:22 PM
rubicon air lockers 03rubiconMG TJ Wrangler Technical Forum 15 09-16-2006 11:42 AM
