Rubicon Locker switches - Page 3 - JeepForum.com
post #31 of 44 Old 01-14-2014, 03:40 PM
ronjenx
ronjenx's Avatar
Originally Posted by Astennis1 View Post
Got bored at work so I made this. FL relay means the front locker relay ect.
Note I have not done this specific wiring for the lockers yet, but is ,from what I understand that the cpu switches on the ground bus, ( which makes since because they can use small switches that do not have to switch under load) technically correct.
Edit: I was thinking about this and you really can sub all of the relays in my drawing for plain ole switches in the cab since you are not on load current. Relays would be a waste of money and wiring time because their is no need to fuse grounds.
Is this a diagram showing where to splice into the OEM system?
Or is it a redesign of the system?
ronjenx is online now
post #32 of 44 Old 01-14-2014, 04:06 PM Thread Starter
Astennis1
I took this from your explanation of:
Splice a switch to ground on the violet/light green wire on the rear locker relay, and a switch on the violet/dark blue wire on the front locker relay. You don't bypass the OEM ground wire. You simply tap your wire onto it. That way, the OEM switches will still operate the locker.
This is just taking it a step further and making a master switch so they cannot be accidentally switched
I LOVE LAMP
13 JKUR
Astennis1 is offline
post #33 of 44 Old 01-14-2014, 04:09 PM
ronjenx
ronjenx's Avatar
I asked because the diagram doesn't look like the OEM circuit.
post #34 of 44 Old 01-15-2014, 02:53 AM
HOKIES2010
2011 JK Wrangler
If I wanted to make a switch to prevent accidental engage I would just make a flip cover for the locker swtiches
My Build
Couldn't have done it without
HOKIES2010 is offline
post #35 of 44 Old 01-15-2014, 06:25 AM Thread Starter
Astennis1
Well I didn't know the oem circuit just went off of what I was told. Either way from the splices out it should work.
This sounds like it is closer to the OEM (plus my splices) from what you talked about in previous post.
Better?
I LOVE LAMP
13 JKUR
post #36 of 44 Old 01-15-2014, 12:14 PM
442Wrangler
In like Flynn.
442Wrangler's Avatar
Originally Posted by brianjw View Post
A locked rear is amazing in soft sand, deep snow etc. It helps to maintain momentum in 4 high rather than having to crawl in 4low. Traction control can really screw you in 4 high in the JK where it cannot be disabled. Not for everyone or every condition but it can be much more helpful in certain instances.
I can disable it (and have) on my 08...so nice to be in control of my car not some crazy compuper.
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #37 of 44 Old 01-15-2014, 08:02 PM
MontyTJ02
Well I didn't know the oem circuit just went off of what I was told. Either way from the splices out it should work. This sounds like it is closer to the OEM (plus my splices) from what you talked about in previous post. Better?
Do we really need all the relays? BTW that diagram was awesome! I'm going to try this mod this weekend.
FireFighter's Jeep Club #84
I started out with nothing and still have most of it left.
Im getting tired of thinking...guess I'll do some wishful drinking.
MontyTJ02 is offline
post #38 of 44 Old 01-15-2014, 08:07 PM
ronjenx
ronjenx's Avatar
No.
Just a wire connected to the violet wire from the OEM locker relay, a switch in the cab, and a short wire from the switch to any handy ground point.
Astennis1,
Yes, your new diagram is much better.
post #39 of 44 Old 01-15-2014, 09:48 PM
INowUnderstand
As mentioned no the extra relays not needed because that curcuit is not handling the high amp power draw of the locker. It is only turning on a relay which is a very small amp draw. So normal switches can handle it. So all you have to do is put switches to connect to ground. You can still put in a master by putting in another switch on a common ground coming from both switches.
INowUnderstand is offline
post #40 of 44 Old 01-16-2014, 06:53 AM Thread Starter
Astennis1
Yeah I forgot about the OEM relays used to switch the lockers in the first drawing, which is why my wiring has relays. Just didn't feel like removing them.
Third times a charm.
I LOVE LAMP
13 JKUR
post #41 of 44 Old 01-16-2014, 08:36 AM
ronjenx
ronjenx's Avatar
Even better, but quite there, yet.
The notes "Splice in between the rear [front] locker ground and CPU" should read
"Splice into the violet wire between the rear [front] locker relay and the cpu".
post #42 of 44 Old 01-16-2014, 12:39 PM Thread Starter
Astennis1
Yeah I missed that, but not changing it. Thanks.
I LOVE LAMP
13 JKUR
post #43 of 44 Old 01-17-2014, 05:41 AM
MontyTJ02
Yeah I forgot about the OEM relays used to switch the lockers in the first drawing, which is why my wiring has relays. Just didn't feel like removing them. Third times a charm.
Perfect! Thanks!
post #44 of 44 Old 01-29-2014, 01:44 PM
ar325
thanks for the post
ar325 is offline
