Rubicon Locker switches - JeepForum.com
post #1 of 44 Old 09-19-2013, 09:48 AM Thread Starter
Astennis1
I have searched for a while to see if I can find a write up, or if someone has done this and I have come up short. I am doing research to figure out how difficult it is to bypass the onboard cpu and make my own switches for the rubi lockers. My plan would be to make a master switch that would have to be closed to use the lockers which would make an accidental engage unlikely. I have heard that the locker uses a momentary signal. My main questions are: Is this a specified pulse duration? Is this a motor that needs a flip in polarity to engage/disengage? Does the locker output its status? I can design a microcontroller to do the logic, but I don't feel this needs to be this complex. Any takers?
I LOVE LAMP
13 JKUR
Astennis1 is offline
post #2 of 44 Old 09-19-2013, 01:15 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
It operates with a simple solenoid with 13.8 VDC on not, spring return as I recall. You could wire them totally independent of the PCM relay operated with master switch and appropriate fuse. May throw a code when PCM cannot find lockers but you could ignore it.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 44 Old 09-19-2013, 01:29 PM
ronjenx
ronjenx's Avatar
A switch in the locker relay ground wire will actuate the locker, completely preserving the OEM circuitry.
Splice a switch to ground on the violet/light green wire on the rear locker relay, and a switch on the violet/dark blue wire on the front locker relay. You don't bypass the OEM ground wire. You simply tap your wire onto it. That way, the OEM switches will still operate the locker.
What it amounts to is, when you close your added switch, it grounds the relay coil, closes the relay contacts, and sends power to the locker.
The only thing you will see that's abnormal is the blinking locker light when you use your added switch to lock the axle.
ronjenx is online now
post #4 of 44 Old 09-19-2013, 02:14 PM Thread Starter
Astennis1
Okay I think I get at what you are saying. I tried to draw how I picture this, to make sure I got it right. Don't hate on my paint skills ha...
I LOVE LAMP
13 JKUR
post #5 of 44 Old 09-19-2013, 02:41 PM
ronjenx
ronjenx's Avatar
Kind of hard to tell, but I don't think that's it.
The violet wire from the relay goes back to the computer. The computer connects it to ground when you select LOCK with the OEM switch. This allows 12 volts to flow through the relay coil.
Your new wire will tap onto the violet wire, go to your new switch in the cab, and go to ground when you close your switch. This will also connect the violet wire to ground, (instead of the computer doing it), allowing 12 volts to flow through the relay coil. The relay will close, sending power to the locker.
It's more like this: (Copy the pic if you want it. I'll take it out of my photobucket later.)
Note to our readers:
Locking one or both axles at inappropriate times can cause the Jeep to become difficult or impossible to control.
If you don't know when not to lock, this mod is not for you.
post #6 of 44 Old 09-19-2013, 02:55 PM
RockyClymer
RedRock4Wheeler
Wow, a lot simpler than my suggestion.
NRA Life member
post #7 of 44 Old 09-20-2013, 12:03 AM
djm
Just curious - why would you want or need to do this ?
Dan
djm is offline
post #8 of 44 Old 09-20-2013, 06:17 AM
mello
Originally Posted by djm
Just curious - why would you want or need to do this ? Dan
you can lock your rear in 2wd which comes in handy on a slick boat ramp. If you need some good wheel speed to clean out tires you can lock them in 4 high.
mello is offline
post #9 of 44 Old 09-20-2013, 11:43 PM
Filthy-Beast
when I was playing in big sand dunes it would have been nice to be able to lock in 4-hi,
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #10 of 44 Old 09-21-2013, 12:54 AM
HllywdJeep
2014 JK Wrangler
Don't some of the programmers make it possible to use the lockers when not in 4low? Not the cheapest route...
HllywdJeep is offline
post #11 of 44 Old 09-21-2013, 12:55 AM
SubAtomicGenius
2011 JK Wrangler
You wife can also switch it on the highway when she's going to get groceries so be careful!
"Wonder what this does??? -click- BBAAAAANNNGGGGGGG!!!! CRASH!!!!
SubAtomicGenius is offline
post #12 of 44 Old 09-21-2013, 06:13 AM
mello
My bypass switch is on my a pillar and I have it running through a weather pack connector in cab before it runs through fire wall. I keep that weather pack connector disconnected except when going off road so there is no accidental engagements. Also if I ever have to remove dash I will not have to cut the wiring.
mello is offline
post #13 of 44 Old 09-21-2013, 08:44 AM
Wonk
When I put ARBs in my TJ I put the switches in the overhead console I built with the feed for both run through a toggle switch with a safety cover on it (arming switch). The main reason for this was because I would let my son drive it to school every now and then on special occasions. The arming switch was there to keep one of his buddies from engaging a locker while cruising down the highway at 60, as in "hey what's this do" click. My son knew what they where for and how to use them.
Wonk is offline
post #14 of 44 Old 09-21-2013, 08:54 AM
Neo1130
2015 JK Wrangler
I still don't understand... People are driving around in 4lo constantly?! The lockers are only available in 4lo. Even with a tuner, you have to have the tuner plugged into the vehicle in order to use it in any other mode. If you hit the locker switch, it will never engage, unless in 4lo... Now what I WOULD like... Tricking the vehicle into thinking it's in 4lo all the time so I can hit the locker switch whenever...
Neo1130 is offline
post #15 of 44 Old 09-21-2013, 09:04 AM
mello
You are not tricking the module to engage with the bypass you are engaging it manually with a switch. My tuner has the 4 high mode and it does not have to be plugged once it has programmed to do so.
mello is offline
