rubicon guys. need a bit of help - JeepForum.com
post #1 of 14 Old 10-08-2013, 11:07 AM Thread Starter
jager00
2005 WK
Okay ive been trying to find a certain item that only comes on the Rubicons. Its the little panel with the locker switches. I've looked and looked but just cant seem to find it. Can someone help me out with a place to buy one other than the stealership. Also are the buttons for the lockers momentary or not? Thanks
heres a pic of what im trying to get but t u e Rubicon version
2007 JK Sahara- trying to figure this one out
2005 WK 9" lift on 37's with all the goodies- regretfully sold :(
jager00 is offline
post #2 of 14 Old 10-08-2013, 11:47 AM
Spank
2014 JK Wrangler
You mean this?
http://www.quadratec.com/products/52446_110.htm
Keep in mind that you can't simply install it and call it good. It will require programming. Unless, of course, you want to wire it up the buttons directly to the lockers.
'14 Wrangler Unlimited Rubicon
Spank is offline
post #3 of 14 Old 10-08-2013, 11:53 AM Thread Starter
jager00
2005 WK
Yes thank you! How does it electronically disconnect the sway bar?
jager00 is offline
post #4 of 14 Old 10-08-2013, 11:59 AM
HappyTrails
Yes, the button for the lockers is momentary push only.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #5 of 14 Old 10-08-2013, 12:46 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
As HT said and jager00 said, you either have to plug it into the canbus system and program it, or you will have to have some flipflop relays and logic as the buttons are momentary contact only as I recall...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #6 of 14 Old 10-08-2013, 06:59 PM
Neo1130
2015 JK Wrangler
I have a schematic that will work... It uses 4 relays wired to act as a latching circuit... If I can find a PDF upload section I'll upload it... If not, I'll convert to a JPG and post that up as well...
Neo1130 is offline
post #7 of 14 Old 10-09-2013, 04:53 PM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
By adding this:
http://www.quadratec.com/products/52446_112_07.htm
Mike
08 Rubicon
"You can't fix stupid" Ron White
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
post #8 of 14 Old 10-09-2013, 04:57 PM Thread Starter
jager00
2005 WK
Lol looks like I'll not be lazy and do it manually
jager00 is offline
post #9 of 14 Old 10-09-2013, 05:06 PM
jrmars07
2010 JK Wrangler
Why do you want all this? This panel is all computer driven and horrible to try and relay anything or put your own switches there. IMO you'd be much better just putting in your own rocker switches.
2010 2dr Wrangler
2.5" ProComp Lift, Front Adj Trackbar, JKS Disco's
Fox Shocks
Tera Front Lower Controls Arms, Rear Upper Control Arms, Synergy HD Balljoints
Tom Woods 1310 Driveshafts
33" KM2's on ProComp 7069 16x8's
Superchips Flashpaq
AEV Premium Front Bumper, IPF 900XSD Lights, Warn 9.5ti w/ Synthetic Line
AEV Rear Bumper, Tuffy Security Deck
D30 Front Sleeved and Gusseted, RCV's, ARB Locked
4.88 G2 Gears
D44 Rear ARB Locked, Chromoly Shafts
jrmars07 is offline
post #10 of 14 Old 10-09-2013, 06:45 PM Thread Starter
jager00
2005 WK
I just want it to look like it belongs there. I like the simple yet functional look. Need to get the piece below that to to get rid of that hole. Its bugging me lol
jager00 is offline
post #11 of 14 Old 10-09-2013, 06:46 PM Thread Starter
jager00
2005 WK
How are those g2 gears treating you?
jager00 is offline
post #12 of 14 Old 10-10-2013, 08:32 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
You might be better off using the switch set from an 11 - they relocated both locker and sway to a panel under the speaker on the far left of the dash... I find it more of an issue getting to it - but only because I learned to wheel in an 05 so am used to reaching with my right hand. Lost track of how many times Ive turned the seat heater on to climb a rock...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #13 of 14 Old 10-10-2013, 08:43 AM
JIMBOX
Just remember that the Rubi "momentary" switchs are only signals to the RUBI programmed ECU and each sw. is associated with a multitude of OTHER REQUIRED sensors to operate the lockers/swaybar/4hi/4lo-etc
I think you're wasting time/money and also jeopardizing your systems integrity/lifespan-possible warranty-
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #14 of 14 Old 10-10-2013, 06:59 PM
Neo1130
2015 JK Wrangler
Good luck
JIMBO
Yes, but he can also set up his own system that will work just as well, without having to go through the ECU and isn't dependent upon all those sensors... As I said, a momentary switch to activate a latched relay circuit, which energizes whatever motor/solenoid he wants...
Neo1130 is offline
