Rubicon express lift question - Page 2 - JeepForum.com
post #16 of 32 Old 08-12-2013, 09:56 AM
nwbronco
2014 JK Wrangler
The RE Arms are adjustable. Pinion correction is fairly straightforward. Front and rear. So instead of calling the long arms for the sake of them being actually longer, which seems to have you in total disagreement. Can I call them adjustable arms, which they are as well. And we can be a bit more agreeable?
Either way, I respect your opinion, and am just expressing mine as well.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
Kid's '08 Yellow JKU
'13 Black 10A Rubicon JKU
nwbronco is offline
post #17 of 32 Old 08-12-2013, 10:02 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
You can call them adjustable arms, but that doesn't detract from the point that they're a lot longer than they need to be. If he already has adjustable arms that came with his kit he isn't gaining anything worthwhile to justify the cost and time investment. JK arms are already in the kid 20s for length, a far cry longer than the 15-16" control arms of the TJ. lengthening them even further past 23-24" isn't going to give you a significant advantage in performance at all.
My builds:
and
or follow us on
spyder6 is offline
post #18 of 32 Old 08-12-2013, 12:11 PM
4wdjeepguy
They're junk. No arguing about it.
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
4wdjeepguy is offline
post #19 of 32 Old 08-12-2013, 12:22 PM
nwbronco
2014 JK Wrangler
Great info. Although I will disagree. I have the 3.5" RE lift on my '07 JKU, and the 4.5 'adjustable arm' on the missus '09 and it articulates much better than mine. On the same trail, she gets through with little to no body roll. Mine gets to the control arm arc end and I am done. No more traction until I push through. I would love to have those arms on my rig. Not any time soon though. We both run 37's, mine are MTRs, hers are Toyo MTs. All that said, I wouldn't pay $500 for those arms unless the seller replaces all the bushings. Poly Performance makes a great replacement set.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
nwbronco is offline
post #20 of 32 Old 08-14-2013, 10:17 AM Thread Starter
bikkerdude
Thanks guys for the input. I passed on that lift and got a 3" teraflex lift instead. I will upgrade to a 4.5" later on.
Thanks again for all the feedback!
2007 JKU
bikkerdude is offline
post #21 of 32 Old 08-18-2013, 11:46 PM
AEVBrute
I have one of the few 2 doors that I have ever seen with a long arm and 5.7 Hemi conversion. If I had to it again I would not do a long arm, dont get me wrong it drives great.
AEVBrute is offline
post #22 of 32 Old 08-19-2013, 07:27 AM
nwbronco
2014 JK Wrangler
Here is the missus' 2DR.
His 14 Anvil JKUR-X
Hers 09 Blue JK
nwbronco is offline
post #23 of 32 Old 08-19-2013, 10:55 AM
AEVBrute
Bob K.
can you explain what you mean by getting to the control arm arc end?
AEVBrute is offline
post #24 of 32 Old 08-19-2013, 12:23 PM
nwbronco
2014 JK Wrangler
The control arm bracket mounted to the axle creates the 'stop' of the arc. My lift is 3.5" about the max for the stock control arms. Running disconnected, the axle will drop out until the axle side hits the stop, and the same for the frame mount. Long before the spring or shock reach their limits.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
nwbronco is offline
post #25 of 32 Old 08-19-2013, 02:28 PM
4wdjeepguy
Idk why you went long arms and still have the same shock size as a mid-arm with the same amount of lift.
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
post #26 of 32 Old 08-19-2013, 03:08 PM
nwbronco
2014 JK Wrangler
Talking two different rigs here. Mine" 07 JKU with 3.5" Rubicon Express standard lift with OME Long travel shocks. This one does not flex as much as:
Hers: '09 JK 4.5" Rubicon Express Long Arm kit.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
nwbronco is offline
post #27 of 32 Old 08-20-2013, 06:13 AM
spyder6
spyder6's Avatar
2010
It's more than long arms though. The factory JK location points will articulate through 16" of travel with no bind with proper components.
The blanketing that the long arm flexes harder than the mid arm is much too vague as there are dozens of individual components that attribute to capability of ones suspension.
My builds:
and
or follow us on
spyder6 is offline
post #28 of 32 Old 08-20-2013, 06:21 PM
SoK66
2009 JK Wrangler
Originally Posted by spyder6 View Post
JKs come from the factory with mid arms. The money spent on long arms vs the gain in specific performance attributed to a longer control arm is not worth it. The same principles from a TJ don't apply to a JK
I thought the same until I drove a long arm JK. I immediately did an upgrade and would never go back. Much more stable on & off road. YMMV, of course, but you can't make a blanket statement that long arms aren't necessary.
OP, from the photo that looks like the early version of the RE 4.5" long arm kit. They had many issues with bushing life on those. I'd pass.
SoK66 is offline
post #29 of 32 Old 08-20-2013, 07:17 PM
4wdjeepguy
Dude you have no idea what you're talking about
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
post #30 of 32 Old 08-20-2013, 08:21 PM
spyder6
spyder6's Avatar
2010
exactly the same thing i just said, you're blanketing a long arm without understanding what and why the long arm is doing for you. i really dislike AEV's suspensions, but id be wiling to bet that an AEV dual sport 3.5 will out handle all of the long arm suspension KIT's available
My builds:
and
or follow us on
spyder6 is offline
