-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Rubicon express lift question (http://www.jeepforum.com/forum/f96/rubicon-express-lift-question-1561065/)
bikkerdude 08-11-2013 09:26 PM
I have a chance to buy a rubicon express lift 4.5" long arm lift for a $500. It is missing all the coil springs and the crossmember. Would you buy this?
I won't be able to get the extra parts for a while. How hard are these lifts to install or are there extra stuff I need?
nwbronco 08-11-2013 09:48 PM
The crossmember is where the front arms mount. Custom brackets are required for the rear arms. Sounds like you are only getting the long arms for $500. Not a bad deal, they run over $200 a piece. Sometines the spares can be found. Make sure you are getting the full lower and smaller upper (it attaches to the lower arm). The stickler may be the frame mount for the rear arms. I do not think I have seen them offered anywhere.
I have a 4.5" long arm on the missus' 09.
NOTE: The install is not for the faint of heart. It took me 4 days to install the lift. You can get the directions on line, maybe at Quadratech.
Bob K.
spyder6 08-12-2013 07:53 AM
Not worth it. Long arms on a JK are a gimmick IMO
JeepNutt1983 08-12-2013 08:08 AM
Spyder...can you explain your statement?
spyder6 08-12-2013 08:17 AM
JKs come from the factory with mid arms. The money spent on long arms vs the gain in specific performance attributed to a longer control arm is not worth it. The same principles from a TJ don't apply to a JK
nwbronco 08-12-2013 08:28 AM
I'd agree with Spyder on anything under 3/3.5". After that, long arms are needed. Especially on a 2DR.
Bob K.
spyder6 08-12-2013 08:31 AM
I disagree fully, and wheelbase as nothing to do with the angle of your control arms.
nwbronco 08-12-2013 08:34 AM
Control arm length dictates driveline placement, and pinion angle, too.
Bob K.
awinski 08-12-2013 08:40 AM
Id be more concerned with finding a way to get rid of that damn track bar first
bikkerdude 08-12-2013 08:52 AM
1 Attachment(s)
here is a picture of what is included.
nwbronco 08-12-2013 09:31 AM
Left to right. first two arms are the fronts. Need the crossmember to mount those. The outside mounts for the rears on laying on them. There is a plate that goes on the backside of the frame and then a couple of threaded slugs go between them. Next are the rear arms. Then the tracbars, swaybar links, and shocks.
Bob K.
nwbronco 08-12-2013 09:32 AM
The stock one, or all together?
Bob K.
spyder6 08-12-2013 09:37 AM
Bob K.
Sure, but that has nothing to do with long arm vs stock length, that's merely a matter of possessing adjustable length arms.
nwbronco 08-12-2013 09:41 AM
So if I replace long arm with adjustable arm in the comments we're good?:thumbsup:
Bob K.
spyder6 08-12-2013 09:47 AM
That doesn't make any sense
The time now is 02:54 PM.
