Rubicon Express? - JeepForum.com
post #1 of 10 Old 09-05-2013, 08:31 AM Thread Starter
Jclilk
Rubicon Express?
So after loong days if thinking I think ima go with a Rubicon Express 3.5 lift kit. I do about 98% on road driving. So anyone got feedback?
Jclilk is offline
post #2 of 10 Old 09-05-2013, 01:02 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
You will probably get better info in the CJ forum....
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 10 Old 09-05-2013, 01:16 PM Thread Starter
Jclilk
But its for a JK lol
Jclilk is offline
post #4 of 10 Old 09-05-2013, 01:29 PM
Astennis1
Which are you thinking about getting the standard, superflex, extreme...
I saw he commented on this when you had CJ listed in your profile
I LOVE LAMP
13 JKUR
Astennis1 is offline
post #5 of 10 Old 09-05-2013, 01:38 PM Thread Starter
Jclilk
Im planning to get the standard coil lift. they got it with the bilstein 5100 for $860
yeah i forgot to change that when i bought my JK
Jclilk is offline
post #6 of 10 Old 09-05-2013, 01:53 PM
Astennis1
I don't own this kit nor have I had experience from RE lifts, but from the looks of it they are using cam bolts, which IMO are not great, to fix the front geometry you may want to look into getting new control arms for the front or a relocation bracket (new CA is better for more abuse) to address this. Other than that as long as that rear track bar relocation bracket is solid the kit looks like it will do fine for what you are trying to accomplish.
I LOVE LAMP
13 JKUR
post #7 of 10 Old 09-05-2013, 02:08 PM
brianjw
Don't do it. Why would you get a 3.5" lift for driving on the street? You'll tear up at least the front driveshaft, probably both eventually. You'll also need a different exhaust y pipe for driveshaft clearance. At 3.5" lift you'd likely want a front track bar bracket (axle side) and flipped drag link too.
Go for a 2.5" lift. But rather than using cam bolts, generic bilsteins and linear springs, consider something like the aev 2.5" lift with progressive coils, tuned bilsteins, bump stops etc. It will work handle much better. Add the geometry correction brackets and cam bolt eliminator washers, and an adjustable front track bar and you'll have a solid handling jeep with good angles, likely no driveshaft problems.
brianjw is offline
post #8 of 10 Old 09-05-2013, 09:44 PM
rgt75
2014 JK Wrangler
you will most likely have bad bushings and poorly manufactured parts. Will last for about 2 months before you have to replace it. You may call the clowns at Rubicon Express and they will tell you about how bushings always corrode no matter who makes them and that the kit must have been put on wrong.
You will get mad and swear at them and they will say too bad. After that you buy a Teraflex or AEV kit and have no problems. The world will seem good again and peace and harmony will ring throughout the land.
rgt75 is offline
post #9 of 10 Old 09-05-2013, 10:19 PM Thread Starter
Jclilk
You guys are right, I've decided to go with a teraflex 2.5 standard kit with bilstein 5100 and than add to it
Jclilk is offline
post #10 of 10 Old 09-06-2013, 07:50 AM
JKommuter
2009 JK Wrangler
I have the Teraflex 2.5" coil lift with their shocks. I ended up adding Front Lower control arms and front adjustable track bar. To save money you could skip the front lower control arms and use the AEV bracket for $99. I think you will want to do something to put some caster back after the lift.
JKommuter is offline
