Rubicon differential sump capacities - JeepForum.com
post #1 of 6 Old 06-01-2009, 10:53 PM Thread Starter
rufrdr
I changed the differential oil today in my Rubicon unlimited. I filled them from a container with a pump on it so I didn't keep track of how much went into each differential but the rear seemed to take more than the front. The manual has no capacity listing for the diffs that I could locate. Anyone have an idea what the fill capacity is for the front and rear?
rufrdr is offline
post #2 of 6 Old 06-02-2009, 07:01 AM
AlterEgo
2.7 pints in the front and 4.75 pints in the rear fo the Dana 44 axles.
The Dana 30 fronts use 2.1 pints.
Gary Greenway - KD8NHC
08 4 Door Rubicon
Member of Two Trackers 4wd Club
Great Lakes Four Wheel Drive Association
United Four Wheel Drive Associations
AlterEgo is offline
post #3 of 6 Old 06-02-2009, 07:50 AM
ronjenx
ronjenx's Avatar
Here are the factory differential capacities for the JK:
FRONT AXLE .03 L (1 oz.)
186 FBI (Model 30) 1.0 L (1.05 qts)
216 FBI (Model 44) 1.3 L (1.35 qts)
REAR AXLE .03 L (1 oz.)
198 RBI (Model 35) 1.83 L (1.9 qts)
226 RBI (Model 44) 2.25 L (2.4 qts)
Actual amounts from factory on my vehicle:
Front Dana 44: 44oz (15oz above bottom of fill hole) (1.4 qts)
Rear Dana 44: 72oz (slightly above bottom of fill hole) (2.25 qts)
The rear takes more because there has to be enough to flow to the outer axle bearings.
ronjenx is offline
post #4 of 6 Old 06-24-2012, 12:13 AM
SSnipes
jk's dont come with dana35's
the D44, locker or no locker, is a little different due to the rear locker. the axle shafts are different lengths slightly
the regular D44 with no locker the axle shafts are the same.
'08 Jeep JKU Rubicon
4" TF Flex Arm, GY MTR with Kevlar 37", ASFIR bumpers, Rock sliders, aluminum skids
SuperWinch EPi9, EVO Gusset, sleeves, control arm rock sliders
Wife's - '01 Jeep Grand Cherokee 4.7L - Stock
ATS 245/70R16
SSnipes is offline
post #5 of 6 Old 06-24-2012, 12:37 AM
ncb
Holy thread dig. Zombie thread. The very early JKs had D35s.
ncb is offline
post #6 of 6 Old 06-24-2012, 02:05 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
The very first run of JK's (non Rubicon) in 2007 model year came with D35's in the rear. This was only done for the first few months of production then was changed to D44 rear as standard equiptment.
On a Rubicon or any modle for that matter the front takes less oil because it does not fill out the axle tubes as it does in the rear.
Jim
JLC08JK is offline
Rubicon differential oil Caribic-TJ TJ Wrangler Technical Forum 15 01-04-2013 11:20 AM
How to remove Rubicon Differential Carrier teglude97 TJ Wrangler Technical Forum 6 01-09-2010 04:21 PM
Rubicon Rear differential leak question ajm1911 TJ Wrangler Technical Forum 5 10-28-2009 09:56 PM
Rubicon differential lock override? Pointblank TJ Wrangler Technical Forum 3 09-04-2007 09:22 PM
03 Rubicon rear differential lock-up rubicon-tom TJ Wrangler Technical Forum 4 08-22-2007 06:16 PM
