Rubicon axles - JeepForum.com
post #1 of 14 Old 08-21-2013, 12:32 AM Thread Starter
onlyjeep
2011 JK Wrangler
Rubicon axles
I was thinking of putting a rubicon axles on my unlimited sports, can anybody give a heads up of what im gonna ba needing?
Thanks....
onlyjeep is offline
post #2 of 14 Old 08-21-2013, 01:08 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
They will swap over directly. The only thing you will need to do is add switches and relays to operate the lockers. You can upgrade the factory switch panel and wire harness then get a dealer flash for stock operation though most people just run their own switches so they aren't limited to 4 low use.
Jim
JLC08JK is offline
post #3 of 14 Old 08-21-2013, 02:02 AM Thread Starter
onlyjeep
2011 JK Wrangler
I broke my rear differential on my unlimited sport and thinking of buying the mopar dana44 rubi axle complete assembled!
I have 3:73 gearing and it has a 4:10 well it complicate if i only replace the rear?
onlyjeep is offline
post #4 of 14 Old 08-21-2013, 07:44 AM
ncb
Front and rear ratio must be the same or things will go boom when put in 4X4. Have the front geared to match and you'll be all good.
ncb is offline
post #5 of 14 Old 08-21-2013, 09:40 AM
Prot
Prot's Avatar
2014 JK Wrangler
You can probably get a stouter aftermarket unit for about the same price. Alternatively, if you can get a used Rubicon axle for a decent price, then that would be the way to go.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #6 of 14 Old 08-21-2013, 10:40 AM Thread Starter
onlyjeep
2011 JK Wrangler
I will buy the dana44 rubicon axle for the front just not right now, cant afford to buy both at the same time.
If i put the dana44 rubi. axle on the rear first without using 4x4 i'll be fine?
And is the front direct swap also?
onlyjeep is offline
post #7 of 14 Old 08-21-2013, 03:17 PM
SubAtomicGenius
2011 JK Wrangler
Buy aftermarket - go for a Dynatrac ProRock 44. May cost about $1000 more in the end but it is a better axle assembly.
SubAtomicGenius is offline
post #8 of 14 Old 08-21-2013, 06:48 PM
Spank
2014 JK Wrangler
Yes and yes. Again, you'll need wiring and what not for the lockers, but it will bolt right in.
'14 Wrangler Unlimited Rubicon
Spank is offline
post #9 of 14 Old 08-21-2013, 07:48 PM
allibaster
I have a Dynatrac axle available for sale at a discounted price. Much stronger than a Rubicon axle. Bolts right in and also corrects for caster after lifting, which the Rubicon axle doesn't do.
The link is in my signature. PM if interested.
'13 JKU 10th Anniversary
allibaster is offline
post #10 of 14 Old 08-21-2013, 08:26 PM
JLC08JK
JLC08JK's Avatar
What part of the rear diff. did you break?
You can put an ARB locker and 35 spline shafts in your current housing and end up with a rear axle that is better than the Rubicon axle. My rear axle build cost about $2k without labor and is described in my thread below.
Jim
JLC08JK is offline
post #11 of 14 Old 08-21-2013, 09:35 PM
Prot
Prot's Avatar
2014 JK Wrangler
Or he can save a a few hundred dollars and go with a Yukon Zip locker, which is an air locker very similar to the ARB.
Personally, I would not install an axle with an incorrect ratio on my Jeep. Essentially, you are making it a two wheel drive. If you do have to do it for whatever reason, then I think you can leave the front drive shaft safely removed, that way there is no possibility of forgetting and putting it four wheel drive and tearing everything up.
Prot is offline
post #12 of 14 Old 04-11-2015, 02:24 AM Thread Starter
onlyjeep
2011 JK Wrangler
Thinking of regearing my front from 3.73 to 4.10 to match my rubi axle on rear. After reading a bunch of write ups and videos on how to, I think i can do it myself.
But before i break it down, i need some info on my d30 carrier.
I have 3.73 right now and putting a 4.10 will i need a new carrier for the 4.10?
I appreciate all the help thanks!!
onlyjeep is offline
post #13 of 14 Old 04-11-2015, 04:08 AM
shouser45
2009 JK Wrangler
Thinking of regearing my front from 3.73 to 4.10 to match my rubi axle on rear. After reading a bunch of write ups and videos on how to, I think i can do it myself. But before i break it down, i need some info on my d30 carrier. I have 3.73 right now and putting a 4.10 will i need a new carrier for the 4.10? I appreciate all the help thanks!!
No you'll use the same carrier 3.73 an up all use the same carrier
shouser45 is offline
post #14 of 14 Old 04-11-2015, 04:33 AM Thread Starter
onlyjeep
2011 JK Wrangler
thanks for the info. You just save me a 100 bucks lol...
onlyjeep is offline
