Rubicon 4:1 transfer case swap into a sport question - Page 2 - JeepForum.com
post #16 of 61 Old 12-20-2012, 05:53 PM
jadmt
2014 JK Wrangler
seems like swapping the rubicon transfer case would be a great way to go for us newbies who did not do enough research and and bought jku's with 3.21 gearing. I have a 2013 jku with auto and am waiting to see how the OP turns on this.
jadmt is offline
post #17 of 61 Old 12-20-2012, 08:34 PM Thread Starter
David_M
I will certainly be doing the swap. Obviously, I will need to exercise patience in finding a 2012/13 rubicon transfer case that came out of an automatic transmission equipped Jeep. It may take some time but eventually I will find one. Thanks to everyone who contributed factual information to this thread.
David M
David_M is offline
post #18 of 61 Old 12-21-2012, 08:22 PM
VEGASROBBI
You should also know the front case from the 5 speed auto is not compatible with the other JK TC's,however, the rear case and many of the insides are.
MoTech
LS Specialists
500 South Buffalo Drive, Las Vegas NV 89145 702-491-7710
www.LSWrangler.com
VEGASROBBI is offline
post #19 of 61 Old 12-21-2012, 09:44 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
For what years are you saying it is not compatible...incomplete info is one the problems on this thread...for a 2008 the tcase is the same for auto and manual.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #20 of 61 Old 12-21-2012, 09:53 PM
jadmt
2014 JK Wrangler
i'm confused too. what will work if anything with a 2013 automatic wanting to swap stock 2.72 transfer case for a rubi 4.10 transfer case?
jadmt is offline
post #21 of 61 Old 12-21-2012, 10:23 PM
VEGASROBBI
OK to keep it simple if you have a 5 speed auto you can only swap TC with another 5 speed auto, Rubi or not.
Virtually everything else from a JK is compatible.
MoTech
LS Specialists
www.LSWrangler.com
post #22 of 61 Old 12-22-2012, 06:59 AM
jadmt
2014 JK Wrangler
thanks. now to find a good price on a suitable tc.
jadmt is offline
post #23 of 61 Old 12-22-2012, 12:00 PM
RockyClymer
RedRock4Wheeler
Now, to confuse things more...the 4:1 tcase on an 08 auto will fit an 08 manual and can be used to replace the 241 to the 241OR. The auto has an essentially empty tailhousing that mates up perfectly and has the proper spline output count according to another site....
edit...I will check the part numbers, but when I ordered mine from a dealer, I recall they were the same part number for 08 (not sure about other years).
NRA Life member
post #24 of 61 Old 01-10-2014, 08:09 AM Thread Starter
David_M
Update! I found a Rubicon 4:1 transfer case out of a 2014 automatic. Needless to say, I already purchased it and it was supposed to ship out yesterday. I'll have it early next week and get it installed shortly thereafter.
I will still have a issue of the computer not recognizing the "new" low range gear ratio. I have spoke with Advanced Adaptors and AEV about this. Advanced Adaptors said that they have been working with BullyDog on a programmer that can program a change in low range gear ratio. AEV said they are working on it and hope to have it out soon. I plan to call my dealer and see if they are willing to do a re-flash for me. I know it can be done but not sure if they are willing. Since it is a factory option, there's no doubt they have the capability. I'll update this thread again after the swap is complete.
David_M is offline
post #25 of 61 Old 01-10-2014, 12:41 PM
TheBoss
Subscribed hopefully all goes well for you.
TheBoss is offline
post #26 of 61 Old 01-11-2014, 01:51 PM
kntnrml
2010 JK Wrangler
So then it sounds like a rubi X-case from an '08 6spd will fit a '10 auto?
If you're not outraged, your not paying attention...
kntnrml is offline
post #27 of 61 Old 01-11-2014, 02:03 PM
VEGASROBBI
Correct
MoTech
LS Specialists
www.LSWrangler.com
post #28 of 61 Old 01-11-2014, 02:17 PM
BigBlue7
2010 JK Wrangler
Awesome. Good luck David!
Rock Krawler | TeraFlex | Synergy | Fox | Poison Spyder | Genright | Nemesis |Beer
BigBlue7 is offline
post #29 of 61 Old 01-11-2014, 03:40 PM Thread Starter
David_M
Thanks! Thank you to VegasRobbi as well. He pointed me in the right direction, that's how I found the '14 Auto Rubicon doner JK.
David_M is offline
post #30 of 61 Old 01-11-2014, 08:06 PM
Ruby_Tuesday
Think about adding the teraflex 2lo kit to your rubi TC while it's out.
Ruby_Tuesday is offline
