Rubicon 2.5" lift sway bar disconnects - JeepForum.com
post #1 of 4 Old 11-27-2013, 08:31 AM Thread Starter
timbotrog
2014 JK Wrangler
I've had my 2003 WG Grand Cherokee V8 for a few years now but my 2014 JKU rubicon arrives next week.
This may sound like a silly question, but do I need to extend the electric sway bar disconnects for a 2.5" lift?
Cheers
Tim
timbotrog is offline
post #2 of 4 Old 11-27-2013, 08:42 AM
ROCKR8R
Rubicon disconnects differently than manual disconnects. It doesn't disconnect at the end links. It is a 2 piece bar coupled together and when you disconnect it un hinges. The end links always stay put. You may want to get some bigger end links though since a lot of 2.5" lifts give you more height than advertised but you may not NEED them. Also wouldn't hurt to get manual disconnects since the Rubi e-disco is always breaking.
-Dan
ROCKR8R is offline
post #3 of 4 Old 11-27-2013, 07:28 PM
HappyTrails
HappyTrails's Avatar
My RK 2.5" Max Travel lift came with longer sway bar disconnects, and I use them instead of the e-disco. Never had a problem with my e-disco breaking. Rather, the sway bar links would bend like a boomerang or break when the suspension was seriously flexed and they somehow came back bound up. RK lifts are seriously flexy, btw. So, I just manually disconnect them instead of pushing the e-disco button.
So, yes, I'd recommend getting extended sway bar links. For the cost, it's worth it.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #4 of 4 Old 11-27-2013, 07:44 PM
brianjw
Yeah they end links get screwed up that way when they aren't long enough. The need to be long enough to compensate for the addition droop in the suspension.
Get some longer end links.
brianjw is offline
