Rubi shocks when changing to rubi springs? - JeepForum.com
post #1 of 2 Old 10-13-2009, 08:02 PM Thread Starter
DocJake
in therapy
DocJake's Avatar
2009 JK Wrangler
I scored a set of unlimited rubi springs (xxx-17 and xxx-18) on ebay for $100 and expect they will likely be stiffer than the #12 and #13 I'm removing (each number higher corresponds to an extra half twist of the coil, with corresponding height increase). As the higher spring rate will mean my 2 door will sit less into the spring range than the old set, I'm anticipating the typical slight height increase.
So now that the springs are different, do I need to swap out the old shocks for new? I have the sahara tow package, which I think means I have gas shocks, at least in the rear. Will the stiffer springs overpower the shocks now? Maybe I should wait and see? Any thoughts folks?
GJ
DocJake is offline
post #2 of 2 Old 10-13-2009, 08:36 PM
BrettDez
I think you'll be fine, but that is just opinion only.
-Brett
My Jeep: 2012 Jeep Wrangler Unlimited Rubicon, 6-Spd Manual, Cosmos Blue
"The Smurf":
Previous Jeeps:
BrettDez is offline
Rubi springs VS stock Sport springs seekrtruth TJ Wrangler Technical Forum 12 08-22-2009 08:58 AM
Need to know Stock 05 Rubi Shock Lengths (Rancho 2.5" shocks on stock Rubi) jtice TJ Wrangler Technical Forum 2 09-24-2008 10:45 AM
Replace Stock Springs with Rubi Springs NewBinCO TJ Wrangler Technical Forum 9 09-01-2006 11:33 PM
Rubi Shocks and Springs on a Sport? TJDrew TJ Wrangler Technical Forum 8 07-29-2004 09:32 AM
Changing Rubi to Synthetic NetJunkie TJ Wrangler Technical Forum 13 03-09-2004 04:14 PM
