Rubi front springs,which side does the stiffer one go on? - JeepForum.com
post #1 of 14 Old 09-02-2012, 05:11 PM Thread Starter
MAC57
Swapping the stock springs in my 08 Sahara for take offs from a 4 door Rubi to help with sagging when I'm towing.Rears are the same part number, fronts though have two different numbers, one ends in 15 and one in 16. On my Sahara they are both 14's. I know the 16 is the stiffer of the two, but which side does it go on, passenger or driver? And why?
MAC 57
03 TJ
MAC57 is offline
post #2 of 14 Old 09-02-2012, 05:20 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
If I had to guess....which is what it is (not sure why two part numbers, the stock on my 08 JK were the same) it would be passenger, because the gas tank is on the right side...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 14 Old 09-02-2012, 05:35 PM
SubAtomicGenius
2011 JK Wrangler
^^^ And the battery!
SubAtomicGenius is offline
post #4 of 14 Old 09-02-2012, 05:39 PM Thread Starter
MAC57
I thought of that, but then thought that the weight varies depending on how full the tank is, so why build it stiiffer on that side when it isn't constant? And my tank always seems to be closer to empty anyway !! My guess was the drivers side would be the stiffer one since the front drive shaft and most of the t case are on that side, Anyone know for sure?
MAC 57
03 TJ
MAC57 is offline
post #5 of 14 Old 09-02-2012, 05:42 PM
BadTrainDriver
Going from 14's to a 15 and a 16 isn't even worth the effort...
Wait and pick up at least 18's.
On the rear, don't change unless at least 58's.
2012 Jeep Wrangler Unlimited Rubicon
Stock, for now...
BadTrainDriver is offline
post #6 of 14 Old 09-02-2012, 06:22 PM Thread Starter
MAC57
Got 59's for the rear,they are on already,gave me a good 1/1/2" of lift, guess my old ones were also sagging after 90,000 kms. Got a bit too much rake to the front now so a little tweek up a level or two should do the trick. So, anyone know for sure which side the stiffer one goes on?
MAC 57
03 TJ
MAC57 is offline
post #7 of 14 Old 09-03-2012, 10:41 AM
MKWrangler
It sounds to me like whoever built that Jeep at the factory screwed up. They should both be the same number.
MKWrangler is offline
post #8 of 14 Old 09-03-2012, 10:47 AM
ncb
My 2009 unlimited Rubicon had the higher number front spring on the right (passenger) side. Some JKs have matching fronts and some have the higher spring rate on the right front side.
ncb is offline
post #9 of 14 Old 09-03-2012, 12:22 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
the higher rated spring is not necessarily for static weight. The auto trans Rubi has the stiffer right spring.
Ever noticed when you put it in 4lo when you shift into drive it torques and the body leans a bit to the right? The Rubis lower transfer makes it worse so a stiffer spring helps absorb and even out the torque. A stick doesn't load when clutched so the standards have equal springs. the right front for an auto Sahara is rated just under the Rubi auto right. The diff is so small that it is conceivable that when marrying chassis to builds they can use one for another in some cases and stay within a wide tolerance - as well as dealer replace some with another in maintenance and repairs...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #10 of 14 Old 09-03-2012, 03:43 PM Thread Starter
MAC57
Thanks J Wm for explaining. Mine is a standard so I should use matching springs then. I'll do what BadTrainDriver suggested and look for a pair of 18's
MAC 57
03 TJ
MAC57 is offline
post #11 of 14 Old 09-03-2012, 04:36 PM
ncb
My standard had a 17/18 front combo.
ncb is offline
post #12 of 14 Old 09-03-2012, 05:16 PM
jcgribks
I'd put the stiffer one on the passenger side as the torque of the motor puts more load on the right side.
jcgribks is offline
post #13 of 14 Old 09-05-2012, 09:00 PM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
This is correct, and also the way my 08 Rubi stick came from the factory. Higher number to passenger side.
Mike
08 Rubicon
"You can't fix stupid" Ron White
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
post #14 of 14 Old 09-06-2012, 12:29 PM
starscream
1981 CJ5
Interesting stuff. I would've guessed left (drivers) side should be stiffer to offset the weight of the driver.
starscream is offline
Benefit of stiffer springs..... clg82 TJ Wrangler Technical Forum 20 06-06-2012 03:39 PM
Stiffer Springs for Front (Mopar Part #) - bumper and related things jeepruski JK Wrangler Technical Forum 3 07-09-2007 08:42 PM
rubicon springs stiffer than others Bill_Dunnigan TJ Wrangler Technical Forum 6 04-08-2007 07:48 PM
Stiffer front springs for stock height? FLMarine TJ Wrangler Technical Forum 20 12-21-2004 10:18 AM
Are the rubi springs 1" taller, or just stiffer than SEs? BNovak TJ Wrangler Technical Forum 8 11-09-2004 07:38 PM
