RTV Sealant For Differential cover - JeepForum.com
post #1 of 26 Old 02-16-2011, 04:15 PM Thread Starter
Thane1
I'm putting my New Rear Diff Cover on this Saturday.
I was told to get RTV Sealant.
Is there a particular type I should get?
I've never done this before, so any help/advice you experienced wrenchers can give me is greatly appreciated!!
2008 JK 23 S
1995 XJ - Sold
1983 CJ5 - Wrecked
Thane1 is offline
post #2 of 26 Old 02-16-2011, 04:27 PM
DBA2GO
I've used Grey (ultra Grey) whatever... I can't find torque specs; maybe your new cover told you what they were?
One foot in the grave & one foot on the gas pedal!!
DBA2GO is offline
post #3 of 26 Old 02-16-2011, 04:48 PM Thread Starter
Thane1
Thanks for the reply,
I have the ARB specs which say to torque them to 25.4 ft/lbs. I just don't know anything about the RTV.
2008 JK 23 S
1995 XJ - Sold
1983 CJ5 - Wrecked
Thane1 is offline
post #4 of 26 Old 02-16-2011, 04:52 PM
DBA2GO
I think the blue would work too?
DBA2GO is offline
post #5 of 26 Old 02-16-2011, 04:53 PM
DBA2GO
1/4" continous bead - then let it kinda set before you put it on... There should be a writeup somewhere here.
DBA2GO is offline
post #6 of 26 Old 02-16-2011, 04:59 PM
Woodchuck
Woodchuck's Avatar
I recommend these:
http://www.lubelocker.com/products/products/view/2/3
I put them one when I replaced the Diff Covers. Actually snapped of a bolt putting the covers on and have yet to replace it and it has been a year since I put them on and zero leaks!!! Just be sure to follow the torque specs...my wrench was broken so I busted the first bolt but after getting a new wrench all was well
'08 Red Rock Unlimited Rubicon / AEV 2.75" Lift with Remote Reservoir Shocks / AEV Heat Reduction Hood / AEV Front & Rear Bumper with Tire Carrier / AEV Skidplates & Rear Corner Guards / Riddler Diff Covers / Mopar Enhanced Rock Rails / Warn 9.5ti Winch / Mopar Gas Cap Cover / 4.88 Gears / IPF 900xs Drive Beams / Eagle Eye HID Spotlights / Daniel Stern Headlights / 17" AEV Pintler Wheels with 35x12.5r17 BFG Mud-Terrain KM2's / Tuffy Security Drawer / sPod and Benchmark Dual Battery System / Cobra 75 CB / Lockpick with Front and Rear Cameras / Katzkin Heated Seats / Line-X Interior / Hitchsafe Key Vault / and a Trasharoo and a lot more little stuff or just stuff I forgot!!!
____oooo
[ l_,[____],
l---L -[OlllllllO-
( )_) ( )_)-o-)_)
Woodchuck is offline
post #7 of 26 Old 02-16-2011, 10:47 PM
McKBrew
JK Wrangler
I went with the blue RTV, no issues.
McKBrew is offline
post #8 of 26 Old 02-17-2011, 12:27 AM
Krush
I went lubelocker and it's very clean and a sure coverage. If you screw up applying the grey blue or black stuff you aren't really sealed. With lubelocker your guaranteed sealed.
Krush is offline
post #9 of 26 Old 02-17-2011, 12:45 AM
5-90
5-90's Avatar
1988 XJ Cherokee
I've never bothered with RTV - just use a paper gasket and torque to 20-25 pound-feet on the screws. Haven't had a leak yet.
I don't like to use RTV on "maintenance" gaskets - I want them to be easy to clean up when I change them. If anything, I'll smear a thin layer of grease on the gasket, or blow some graphite on it to improve the release of the thing later...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #10 of 26 Old 02-17-2011, 01:29 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
There is an RTV that is labeled for differential covers and other oil contact areas.
I don't know how much better it is though since it's for diff's thats what I got!
All the JK torque specs are listed at the end of the F.A.Q.
Jim
JLC08JK is offline
post #11 of 26 Old 02-17-2011, 05:43 AM
blingII
That is the black stuff. I like using the "cheese wiz" type dispensers. You can find it labeled "Right Stuff". It makes laying a nice, thin and contiguous bead a snap.
http://www.permatex.com/brand_right_stuff.html
blingII is offline
post #12 of 26 Old 02-17-2011, 08:30 AM
kswyg001
2010 JK Wrangler
Paper gaskets are easier. If you smudge the cover a little bit when you're torqueing then you have no worries. But+ for what it's worth- I took my JK to the dealer for the diff bolts having some moisture and they used a silver RTV.
kswyg001 is offline
post #13 of 26 Old 02-17-2011, 09:51 AM
Blu-Jacket
2009 JK Wrangler
If you want to get technical, here's the part number for the Mopar factory RTV. 05013477AA. When applying, it says to install the covers within 3-5 minutes and use a criss cross pattern when tightening the bolts.
Blu-Jacket is offline
post #14 of 26 Old 02-17-2011, 01:46 PM
OregonVette
Rant!
Rant on...
Rugged ridge diff covers!!!!
Do not buy these 69.00 crappy covers. The welds were performed by blind monkeys from china, the 5 tiny hex head bolts are made from the same strength metal as wrigleys gum wrappers which are so soft 3 of the 5 bolts stripped & lost their integrity and I am pissed after spending 4 hours boring out a hole after applying rtv gooey mess all over trying to re-re install the oem diff cover bolts.
&$ck you china and shame on me for thinking there's no difference between these and the warns... Tsk tsk tsk
WTF is up with ****ty hardware and bolts made out of the worse grade ww2 Chinese metal. ?!?!?
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline
post #15 of 26 Old 02-17-2011, 02:25 PM
TheBoss
Best bet is the grey RTV from Mopar or Perma -Tex black Rtv.
TheBoss is offline
8.8 Differential cover??? NHfireLJ YJ Wrangler Technical Forum 31 01-28-2013 01:36 AM
Differential Cover XDS22 TJ Wrangler Technical Forum 2 10-04-2007 10:10 PM
Differential sealant Raindem YJ Wrangler Technical Forum 8 02-08-2007 08:41 PM
8.8 Differential cover Tomb Raider YJ Wrangler Technical Forum 14 09-12-2006 09:46 AM
which differential cover bikerjeep TJ Wrangler Technical Forum 17 07-27-2005 04:00 PM
