RPM dont go over 4 on N - JeepForum.com
post #1 of 15 Old 09-25-2013, 07:15 AM Thread Starter
DxBterrorist
The other day I was with my friends and they started challenging each other on who's car is louder and I thought ill just join for the fun of it, so I put my car on neutral and hit the gas peddle but the RPM didn't go above 4.. Is that a technical problem or this is the standard thing on a 2013 Sahara unlimited?
DxBterrorist is offline
post #2 of 15 Old 09-25-2013, 07:17 AM
ncb
Keeps people from doing foolish revving and blowing up the engine.
ncb is offline
post #3 of 15 Old 09-25-2013, 07:20 AM Thread Starter
DxBterrorist
So it's a standard thing on the new pentastar?
post #4 of 15 Old 09-25-2013, 07:30 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
It's probably more along the lines of the engine can't sufficiently cool itself at that load in a stationary position, so it doesn't allow it
My builds:
and
or follow us on
spyder6 is offline
post #5 of 15 Old 09-25-2013, 07:36 AM
tjkj2002
2002 KJ Liberty
Been a standard thing on many engines in the last 20 years.
tjkj2002 is offline
post #6 of 15 Old 09-25-2013, 07:52 AM
Millermagic
Avoids neutral bombs as well. Transmissions do not like neutral bombs.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #7 of 15 Old 09-25-2013, 08:52 AM
Vince1
2010 JK Wrangler
LOL. At racing school they fine us $50 every time we high rev the engine (6K RPM limit for the Ferraris, pretty easy to do on the track). They say over time it helps pay for the added repairs. Why would anyone sit in N and see how high they can rev their engine? Rednecks, got a love em!
Vince1 is offline
post #8 of 15 Old 09-25-2013, 09:10 AM
robplumm
apparently they live in the desert, too
robplumm is offline
post #9 of 15 Old 09-26-2013, 10:51 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
No load over rev limit... almost all cars post 2007 have it to some extent. My Northstar will go to 7200 with a load - with partial load (like downhill) 6500 - with no load it will only hit 4100. Load is sensed by the readings from all flow sensors.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #10 of 15 Old 09-26-2013, 10:55 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Which school?
Its not just paying for added repairs. Its much like expense for brakes tires etc - everytime you have all those moving parts "bouncing, floating and reverse loading" you have used time off your maint intervals for everything, like bearings, races, valve tip faces cam lobes etc... this is the same logic being used to apply to an engine designed specifically to use itself up at 590 miles for a 500 mile race. Engines make best power just before their wear has hit the limits (obvious loss of parasitic drags). On TF drag cars they have planned maint at every run, bearings, rings, seals etc, pistons at three runs etc...
post #11 of 15 Old 09-26-2013, 03:03 PM
Vince1
2010 JK Wrangler
Originally Posted by jwmbishop View Post
Which school?
Racing adventures. It's in their contract. It actually helps motivate being smooth and efficient on the track. Hitting a cone in their Lambo is a $5K error so control is key.
Vince1 is offline
post #12 of 15 Old 09-26-2013, 09:01 PM
rirrgang
It keeps dumb a$$es from over reving their engines in neutral. My motor home has a 8.1 ltr V8 in it. It will not rev above 3k rpm in neutral.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #13 of 15 Old 09-27-2013, 08:29 AM
Monkeybomber
Yeah thats a rev limiter. My first car was an 04 PT Cruiser (yeah, coolest car ever!). Motor wouldn't go over 3.5K while stationary. I'd imagine its the same thing going on here.
Monkeybomber is offline
post #14 of 15 Old 09-27-2013, 09:55 PM
Butterjeep
2015 WK
Be sure to redline your motor when it's not warmed up. That'll make up for the damage you've avoided by limiting the revs to 4k in neutral.
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #15 of 15 Old 09-29-2013, 09:48 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Hold throttle to floor, turn key to start and release key, count to 60 slowly, release foot from throttle.
Ain't that the correct way to cold start a vehicle?
Don't forget when you change your oil to run it for ten minutes after you drain the old stuff out and before you put the drain plug or new stuff in - just to make extra sure all the dirty stuff gets pumped out....
